Today Only we have two sweet products pleading to be in your system. Improve your graphics dramatically and boot speeds, game loading times.
XFX ATI Radeon HD 6990 4096MB GDDR5 PCI-Express Graphics Card @ £575.99 inc VAT
The XFX Radeon™ HD 6990 creates the ultimate in intense, immersive HD gaming with raw performance, Dual GPU, 4 GB GDDR5 high-speed memory and an impressive array of ground-breaking features, giving even the most hardcore gamers an extra boost of adrenaline to take the game to the next level.
Immerse yourself with the XFX Radeon™ HD 6990 enabling DirectX 11 gaming on up to four simultaneous displays utilizing up to four Mini-DisplayPort 1.2 outputs, as well as Stereoscopic 3D gaming and Blu-ray 3D playback with AMD HD3D technology - all from a single graphics card.
In addition, AMD's exclusive anti-aliasing platform, Morphological Anti-Aliasing (MLAA), reduces and smoothes jagged lines to enhance visual qualities without lowering frame rates associated with standard anti-aliasing. Not all games have anti-aliasing support, but MLAA can enhance your graphics on any application.
Specifications
- Chipset Cayman x 2
- Bus Type - PCI-E 2.1
- GPU Clock - 830 MHz
- External Power - 6-Pins 0
- External Power - 8-Pins 2
- Memory Bus - 256 bit
- Memory Clock - 5.0 GHz
- Memory Size - 4 GB
- Memory Type - DDR5
- Thermal Solution - Fansink
- Minimum Power Supply Requirement - 750 Watt
- XFX Recommended Power Supply - XFX 750W XXX edt PSU
Only £575.99 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £69.98 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £69.98 inc VAT.
ORDER NOW
Specifications
ORDER NOW
- Capacity: 60GB
- Warranty: 3 Years
ORDER NOW
