Get yourself a new PSU today. Y'never know when you'll need one, so it's probably handy to keep one spare. Or two if you have one spare already.
Seasonic G series 550w '80 Plus Gold' Modular Power Supply @ £69.95 inc VAT
For the ultimate in low wattage, high quality PSU needs comes the Seasonic G Series PSU with 360 / 450 / 550 and 650w options these units are perfect for any HTPC or mid range gaming system.
- 80 Plug Gold Certified
- DC to DC Converter Design
- Tight Voltage Regulations (±3%)
- Smart and Silent Fan Control
- High Reliable Aluminum Electrolytic Capacitors
- Conductive Polymer Aluminum Solid Capacitors
- Detachable Modular Cables
- High Current Gold Plated Terminals
- 12cm Ball Bearing Cooling Fan
- Ultra Ventilation (honeycomb structure)
- Mulit GPU Technology Support
- Universale AC Input
- 5 Year Warranty
Only £69.95 inc VAT.
ORDER NOW
__
OCZ CoreXtreme 500w '80 Plus' Power Supply @ £29.99 inc VAT
The OCZ CoreXStream Series is the ideal value upgrade to satisfy essential computing needs with worry-free compatibility. The PSU is kept supremely cool with a load-controlled 120mm fan to remain quiet under load, and provides ample cable lengths for your home system application. Featuring up to 80% efficiency under typical load environments, this power supply remains rock solid and stable under pressure. Combined with a sleek look and elegant black powdercoat finish, you can be rest assured this PSU will look as good as it performs in your home office system.
- Ideal value option for home users and upgraders on a budget
- Ample cable lengths to suit various applications and system configurations
- Continuous output rated at 30¢XC ambient temperature
- 80% efficient at typical loads
- Dual +12V rails for efficient power distribution in your system.
- Compliant with ATX12V v2.2 standard for worry-free compatibility
- A temperature and load controlled 120mm fan for whisper quiet operation
- ErP compliant for low power usage in standby
- Active Power Factor Correction (PFC) to effectively regulate input voltage
- Heavy-duty protection circuitry, (over-voltage, over-power, and short circuit) for protecting your valuable components
- Safety Approvals: CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
- Elegant black powdercoat finish for a sleek and simple look
- 3-Year OCZ PowerSwap Warranty, no endless return-for-repair loops
- 1 x 20+4-pin ATX
- 1 x 4+4-pin ESP/12V CPU
- 1 x 6+2-pin PCI-E
- 1 x 6 pin PCI-E
- 2 x 4-pin Peripheral
- 4 x 5-pin SATA
- 1 x FDD
Only £29.99 inc VAT.
ORDER NOW
- 5 Year Warranty
ORDER NOW
__
- 1 x 20+4-pin ATX
- 1 x 6+2-pin PCI-E
- 1 x 6 pin PCI-E
- 4 x 5-pin SATA
- 1 x FDD
ORDER NOW
