Razer Mamba 2012 4G 6400 DPI Wireless Mouse @ £104.99 inc VAT
The new Razer Mamba returns with an ultra-precise 4G Dual Sensor System, that makes use of both a laser and an optical sensor to enhance tracking precision by calibrating to different surfaces and allowing adjustment of liftoff tracking distance. With up to 15% improved battery life for more untethered gaming enjoyment, a new multicolored LED for personalization, and outfitted with an industry-leading gaming grade wireless technology, the Razer Mamba is still in a league of its own.
Experience a new standard of gaming precision with the 6400dpi 4G Dual Sensor System, outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional pinpoint tracking. The Razer Mamba can not only match the speed of your swipes, but also allows configuration of cutoff distance to manage liftoff tracking, empowering you with more control than ever, no matter the play style.
The Razer Mamba has 15% more battery life than its predecessor, letting you game unwired for longer. When you need to recharge, just pop it on the sleek charging dock which also acts as the wireless receiver unit.
With the new multicolored LED that has over 16 million colors, customize the Razer Mamba to suit your personal style or mood. This is your gaming weapon and yours alone.
- Gaming Grade Wireless Technology
- 6400dpi 4G Dual Sensor System
- Dual mode wired /wireless functionality
- 1000Hz Ultrapolling /1ms response time
- Multi-Color Lighting
- Up to 200 inches per second* /50g acceleration
- Approximate Size : 115 mm / 4.53” (Length) x 68 mm / 2.68” (Width) x 43 mm / 1.69” (Height)
- Approximate Weight: 136 g / 0.30 lbs
- Battery Life: Approx 16 hrs (continuous gaming)
Only £104.99 inc VAT.
ORDER NOW
_____
Asus DSL-N55U Black Diamond Dual Band Wireless-N Gigabit Router @ £84.95 inc VAT
As the first ASUS N600 simultaneous dual-band Wi-Fi ADSL router, the DSL-N55U provides a stylish design, sophisticated features, and easy setup alongside supreme wireless and wired networking for the home.
Two USB 2.0 ports allow the DSL-N55U to share printing and scanning functions on a network, and operate as high-speed NAS (Network Attached Storage) when an external storage device is connected. It is fully DLNA certified, and can act as a media server and home entertainment center. Any device, such as a PS3, iPhone, or Eee Pad can directly stream music and video wirelessly through the DSL-N55U.
For wired networking, four Gigabit Ethernet ports provide excellent capacity. Support for up to 300,000 data sessions means the DSL-N55U has around 20 times the networking capacity of other home routers. Data transmission stays fast even when the router is under heavy load, and easy-to-use QoS settings assure that important traffic - VoIP calls or online gaming - isn't adversely affected by large file downloads.
• Integrated home gateway with independent CPUs for modem and router
• Dual-band Wi-Fi delivers up to 600Mbps in bandwidth
• 4x Gigabit Ethernet ports provide enhanced wired network performance
• Auto-detecting ADSL connection with CD/manual-free setup
• Finest P2P experience via 300,000 concurrent data sessions
• File sharing, printer sharing, and iPad charging using multi-functional twin USB ports
Only £84.95 inc VAT.
ORDER NOW
ORDER NOW
_____
ORDER NOW
