Today Only - 21/04/2012 - 23/04/2012 - Corsair Survivor 32GB USB 3.0 Flash Drive + Sapphire HD 7970
20 Jul 2009
The bleak North East arm pit of Britain
Hello
Today Only we have 50 units of the Corsair Flash Survivor® 32GB USB3.0 Flash Drive (CMFSV3-32GB) for just £29.99inc VAT saving £3.96inc VAT!
We also have 20 units of the Sapphire HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion for only £399.95 inc VAT saving £30.00!!
Take a look below :)
Corsair Flash Survivor® 32GB USB3.0 Flash Drive (CMFSV3-32GB) @ £29.99 inc VAT
Your files are important — that's why you're taking them with you. Flash Survivor USB 3.0 helps keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
- Capacity: 32GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
Was £33.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Sapphire HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £399.95 inc VAT
The SAPPHIRE HD 7970 OC Edition features SAPPHIRE’s new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load. The HD 7970 from AMD is the most powerful single chip GPU ever built - it has a new internal structure with 32 compute units and a total of 2048 Stream processors. The SAPPHIRE HD 7970 OC Edition ships with a raised core clock speed of 950MHz, and 1425MHz for the memory. Its Dual BIOS switch allows users to select the higher performance settings of 1GHz core and 1450MHz memory, making the fastest card in its class. This setting also uses a more aggressive fan profile and raises the limits for maximum overclocking.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5800MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 2yr Warranty
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
Was £429.95 Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
http://www.overclockers.co.uk/showproduct.php?prodid=GX-297-SP
'Fastest single GPU graphics card on the planet'.
But the VTX is faster by 50 Mhz?
The GPU is the same on both. Its MHz rating as you have pointed out is not. What you need to consider is that when this card was added to site it could well have been and as such it may now not be (GTX680s for example)
Still the fastest single GPU (debatable) as its the 7970 used :)
By the end of the month they'll probably all be near this price, regardless of anyones talk of low yields.
