Today Only we have some great graphics and memory deals! Make sure you don't miss out on either of them!
Sapphire HD 6950 OC "Dual Fan Edition" 2048MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
The SAPPHIRE HD 6950 OC is a new SAPPHIRE original model with a special cooler using a new Dual-X cooler. Based on the latest high end AMD GPU architecture, it boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. With its clock speed of 820MHz for the core and 2GB of the latest GDDR5 memory running at 1250Mhz (5 Gb/sec effective), this model speeds through even the most demanding applications for a smooth and detail packed experience.
A Dual BIOS feature allows enthusiasts to experiment with alternative BIOS settings and performance can be further enhanced with the SAPPHIRE overclocking tool, TriXX
Features:-
- Core Clock: 820MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 x Dual-Link DVI-I, 1 x Single-Link DVI-D, 1 x HDMI, 1 x DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- 450W minimum PSU recommended
- Warranty: 2 Years
Only £149.99 inc VAT.
ORDER NOW
Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit @ £49.98 inc VAT
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB).
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
<strong>Features:-</strong>
- Model Name: MV-3V4G3D/US
- Main Board: INTEL/AMD
- System: DESKTOP/SFF
- System Type: DDR3
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets
- CAS Latency: 11-11-11-28 1N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.25-1.55V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM Low Profile
- Warranty: Lifetime
<strong>
Overclocking Features (Not Guaranteed)</strong>
- 1600MHz (7-8-8-24 1N) @ 1.40v
- 1866MHz (9-9-9-27 1N) @ 1.40v
- 2000MHz (9-10-10-28 1N) @ 1.45v
- 2133MHz (10-10-10-28 1N) @ 1.45v
- 2400MHz (11-11-11-28 2N) @ 1.50v
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M
Only £49.98 inc VAT.
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- System Type: DDR3
<strong>
ORDER NOW
