**Today Only 21/06/2012** Akasa Venom 550w Modular '80 Plus' Power Supply & Samsung 128GB SSD 830 D
22 Mar 2011
Cheshire
Check out todays great special offers on the AKASA Venom Power 550w modular PSU and the Samsung Samsung 128GB SSD 830 Desktop Series.
Akasa Venom 550w Modular '80 Plus' Power Supply @ £49.99 inc VAT
AKASA Venom Power 550w modular PSU comes with 80% high efficiency and features a 135mm quiet fan.
- Form factor: ATX 12V 2.3
- Dimensions: 150 x 158 x 86mm (W x L x H )
- Typical efficiency: Over 80%
- Power Factor Correction: Active PFC
- Fan: 135 x 135 x 25mm, thermal control
- Motherboard connector: 1 (20+4pin)
- ATX12V connectors: 1 (4+4pin)
- PCIe 6+2pin connectors: 2
- SATA connectors: 6
- Molex 4pin connectors: 6
- FDD 4pin connectors: 2
Was £64.99 Inc. VAT
Only £49.99 Inc. VAT
ORDER NOW
Samsung 128GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC128D/EU) @ £79.99 inc VAT
Outstanding Performance in Multi-Tasking
Samsung’s fast random read speeds (up to 80,000 IOPS) maximize performance* when it matters most. A Samsung SSD is the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
Lightning Fast Speed. At Your Command
The 830 Series’ 520MB/s sequential read speed provides lightning fast access to your files, loading large multimedia files quickly and smoothly.
Sustained Performance and Unrivaled Reliability
Samsung SSDs are designed and build completely in-house. The Samsung SSD 830 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially- engineered wear-leveling and garbage collection algorithms.
A Complete, User-Friendly Solution
The Samsung SSD 830 series is available with a user-friendly installation kit, including a full version of Norton Ghost, an interactive installation guide, and premium installation tools for both desktops and laptops.
Toggle DDR NAND Flash
Use the wider image option when adding this feature. We would like to capture all of the data represented on this specific feature image. However, do not use this feature image in this document, use the actual image in images folder. Samsung’s 20-nanometer-class toggle DDR NAND Flash chips enable data transfer rates of up to 133 megabits per second (Mbps)-more than three times faster than conventional (40 Mbps) single-date-rate (SDR) NAND Flash chips.
3-core ARM9-based MCX Controller
While most SSD makers rely on generic, dual-core controllers, Samsung has developed its own proprietary, triple-core MCX controllers that excel in multi-tasking and help to assure stead performance over time. Based on an ARM9 controller, its three CPU cores can execute multiple instructions such reading data, writing data and optimization.
256MB DDR2 DRAM Cache Memory
256MB of DRAM cache memory helps maintain stable random read performance, even if the access range is increased.
The Samsung SSD 830 Series boasts superior random read speeds (up to 80,000 IOPS) and faster
sequential read and write speeds (up to 520 MB/s & 400 MB/s respectively). It’s the ideal solution for
Samsung’s SSD Magician software eliminates the confusion and uncertainties of SSD management,
making it simple for users to maximize the performance and lifetime of their Samsung SSD. The
software helps to maintain the SSD at its peak condition, giving you the same great performance and
reliability throughout the life of your PC. In addition to its performance maintenance features, SSD
Magician also provides system information and facilitates performance benchmarking, performance
optimization, OS optimization, firmware updates, secure erasing, and over provisioning.
- Capcity: 128GB
- 256MB DDR2 Cache
- 3-Core ARM9 Risc MXC Controller
- Dimensions (LWH): 100 x 69.5 x 7 (mm)
- Samsung Toggle NAND
- Sequential Read: 520MB/s
- Sequential Write: 320MB/s
- 4K Random Read: 80,000 IOPS
- 4K Random Write: 30,000 IOPS
- Warranty: 3 years
- Norton Ghost
- SSD 2.5"-3.5" tray
Was £139.99 Inc. VAT
Only £79.99 Inc. VAT
ORDER NOW
