**Today Only 21/06/2013** Asus GeForce GTX 770 DirectCU OC 2GB & Razer Tiamat Elite 7.1 Surround Sou
22 Aug 2010
Couple of deals to start Friday off with! If you've not already seen, we've got some immense deals on Corsair coolers too here: http://forums.overclockers.co.uk/showthread.php?t=18521571
Asus GeForce GTX 770 DirectCU OC 2048MB GDDR5 PCI-Express Graphics Card @ £339.95 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1058MHz (GK104)
- Core Boost Clock: 1110MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £339.95 inc VAT.
ORDER NOW
Razer Tiamat Elite 7.1 Surround Sound Analog Gaming Headset @ £143.99 inc VAT
nonl2br
<br>
Behold the Razer Tiamat 7.1, the world's first circumaural gaming headset with 10 individual drivers built-in to deliver the ultimate 7.1 Surround Sound experience. Dominate deathmatches when you can hear incoming enemy footsteps to prevent backstabs and pinpoint enemy locations through gunfire with absolute precision. No other surround sound headset has been engineered to produce such lifelike positional audio geared for the ultimate tactical advantage.<br>
<br><br>
Total audio mastery in your hands. Set the volume, audio positioning and bass depth as you want via the audio control unit. Whether it’s configured to blast a full frontal wall of sound or scaled down to simple stereo, get the right level of intensity for your gaming audio every time.<br><br>
<b>7.1 surround sound with lifelike positional audio</b><br>
A world’s first, the 10 individual drivers in the Razer Tiamat 7.1 provide immersive, crystal clear surround sound. The reproduced audio is so rich and lifelike that not only will you feel like you’re right there, you’ll have the edge over your enemies. Let ‘em try sneaking up on you now.
<br><br>
<b>Full audio customization</b><br>
Easily and accurately fine-tune the level of each audio channel, position, and bass depth to your exact enjoyment using the supplied control unit.
<br><br>
<b>Maximum comfort, maximum durability</b><br>
The Razer Tiamat 7.1’s sturdy construction and padded leatherette ear cups ensure extended headset life and ultimate comfort so you can keep going during those hardcore marathon gaming sessions.
<br><br>
• True-to-life 7.1 Surround Sound from 10 discrete drivers<br>
• All-in-one volume control unit for multi-channel customization and toggling between headset and speakers<br>
• Comfortable, snug fit for extended play<br>
• Retractable, noise-filtering unidirectional mic<br>
• Interchangeable ear cup covers<br>
• Replaceable soft-touch leatherette ear cushions<br>
• Braided fibre cable<br>
• PC with built-in 3.5mm audio jacks & 1 USB port<br>
• 7.1 Surround Sound-enabled Sound Card (for 7.1 Mode)<br>
Only £143.99 inc VAT.
ORDER NOW
