**Today Only 21/07/2012** Asus PA248Q & KFA2 GeForce GTX 580 OC MDT
rjk
rjk
Caporegime
8 Aug 2007
KFA2 GeForce GTX 580 OC MDT 1536MB GDDR5 PCI-Express Graphics Card with FREE NVIDIA GPU Keyring @ £249.95 inc VAT
This card supports a total of 4 monitor outputs simultaneously (3 Mini-HDMI, 1 DP). User has the flexibility to use 3 of the Mini-HDMI ports to combine into a single monitor span in windows, creating a surround gaming environment.The card supports 5760x1080@50Hz (1920x1080 on each monitor) in 4 monitor mode.
Features:-
- Core Clock: 840MHz (Fermi GF110)
- Tri-Fan, superior and quieter cooling over reference design
- MDT: Multi-Display model - Upto 4 monitors
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1600MHz
- 3x mini HDMI to HDMI cable
- 3x HDMI to DVI converter
- DP to DVI-D cable
- Powered by IDT ViewXpand VMM1402
- 2x2 display stacking
- 4x1, 3x1, 2x1 line-up
- Virtual single monitor mode up to 3 (50 MHz) displays 1080p
- Three Mini-HDMI and One DisplayPort connectors
- Bus Type: PCI-Express 2.0
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Supplied with FREE KFA2 NVIDIA GPU Keyring worth £9.95
Only £249.95 inc VAT.
ORDER NOW
Asus PA248Q 24.1" Professional ProArt Widescreen IPS LED Monitor - Black @ £339.95 inc VAT
Experience professional-grade color fidelity and reproduction with the ASUS PA248Q ProArt series LCD display. Each PA248Q guarantees industry-leading color accuracy, having been pre-calibrated to minimize the color different to ?E < 5 right out of box. The PA248Q delivers 100% sRGB color reproduction on its 16:10, 1920 x 1200 optimal HD A+ IPS panel with 178° ultra-wide viewing angle. It is the world’s first monitor with four USB 3.0 ports, ensuring enhanced productivity thanks to data transfer speeds that are up to 10X faster than Current USB 2.0 standards.
The out-of-box settings are impressive as each PA248Q is pre-calibrated at factory to prove the best color accuracy. To ensure that each PA248Q produces the most accurate and consistent color, we carefully measure its ?E and gamma value and track its gray-scaling. It even supports both Gamma 2.2 for PC and Gamma 1.8 for Mac – offering users more flexibilities to work with. Each PA248Q guarantees industry-leading color accuracy, having been calibrated to minimize color difference to ?E (Delta E) of less than 5 – ensuring precise reading of color input and guarantees excellent color fidelity.
The ASUS PA248Q features a 16:10 aspect ratio, 1920 x 1200 A+ IPS LED-backlit panel for 100% sRGB and 72% NTSC color reproduction; addititionally, along with a 178° wide viewing angle, it ensures quality visuals and minimal onscreen color shift from almost any viewing position. With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 300cd/m² of brightness, the ASUS PA248Q enhances display contrast and sharpness – by adjusting the luminance of the backlight to achieve the darkness black and brightest white – delivering lifelike visuals.
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors. ASUS PA248Q also delivers ultra-smooth visuals thanks to a 6ms (GTG) response time – ensuring users have a lag-free viewing experience when it comes to watching movies or playing games. Games played under the PA248Q are more vivid – as all details can be seen and true color can be shown with the PA248Q.
PA248Q sets a standard by being the world’s first monitor with four USB 3.0 ports; users can easily plug in their devices and experience ultra-fast transmission speeds that are up to 10 times* that of current USB 2.0 standards. An extensive array of connectivity and high compatibility options are available with the PA248Q including DisplayPort, HDMI, DVI and D-Sub; the PA248Q also allows users to use up to two or three displays simultaneously.
With award-winning design, fast response time and advanced visual technology, DisplayPort-ready PA248Q gives you a leading multi-display experience – so you can see all the true color and every detail brilliantly. ASUS Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters according to ensure color accuracy and image fidelity. Six preset modes (Scenery, Theater, sRGB, standard and two user modes) can be selected via a designated hotkey.
The PA248Q has a 5-way navigation key that acts as a joystick that gives access to the QuickFit Virtual Scale function along with all OSD functions and settings. The PA248Q features customizable OSD shortcuts through two designated hotkeys for quick access to the 10 most frequently used OSD functions. ASUS exclusive innovations Picture-in-Picture (PIP) and Picture-by-Picture (PBP) allows users to view images from different signals in almost anyway they want. PIP and PBP let users view images from different signals and let them switch between the main and PIP source, including audio, easily. SUS included its exclusive QuickFit Virtual Scale Function with the PA248Q, allowing users to preview photos and documents on screen in their actual sizes prior to printing. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. Additionally, the PA248Q also comes with a choice of seven different background colors for users to choose from.
Features:-
- Professional-grade color fidelity with pre-calibrated ?E <5 for industry-leading color accuracy
- True, precise colors on a 100% sRGB, 16:10 aspect ratio, 1920 x 1200 optimal A+ IPS panel
- The world's first monitor with four USB 3.0 ports for 10X faster transfer
- ASUS-exclusive innovations like QuickFit, Splendid™ and 5-Way navigation key for enhanced productivity
- A comfortable viewing experience with award-winning ergonomic design with tilt, swivel, pivot and height adjustments
Specification:-
- Panel Size: Wide Screen 24.1"(61.13cm) 16:10
- Panel Type : IPS
- True Resolution : 1920x1200
- Pixel Pitch : 0.270mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 80000000:1
- Viewing Angle (CR?10) : 178°(H)/178°(V)
- Response Time : 6ms (Gray to Gray)
- Display Colors : 16.7M
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Color Temperature Selection : 4 Modes
- Color Accuracy : ?E? 5
- Gamma adjustment : Yes (Support Gamma 2.2/1.8 )
- Color Adjustment : 6-axis adjustment(R,G,B,C,M,Y)
- QuickFit (modes) : Yes ( Modes)
- Picture-in-Picture
- Picture-by-Picture
- HDCP support
- Signal Input : HDMI , D-Sub, DisplayPort, DVI-D
- Audio Output : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- USB Port(s) : 1 x upstream, 4 x downstream
- Chassis Colors : Black
- Tilt : -5°~+20°
- Swivel : Yes
- Pivot : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Kensington lock
- Phys. Dimension with Stand(WxHxD):557.2x416.3x235mm
- Phys. Dimension without Stand(WxHxD):557.2x362.8x62mm(For VESA Wall Mount)
- Box Dimension (WxHxD):681x439x292mm
- Net Weight (Esti.):6.4kg
- 3yr Warranty
Only £339.95 inc VAT.
ORDER NOW
Opinions on this 580 vs the £239 7950's at the moment? Gaming at 1080p. I prefer nvidia (seem to be better quality inc. drivers in my experience) but if the 7950 is better...
EDIT: 670 worth the premium? Currently have a 5870, and 570 is available second hand for £140 nowadays...
IMO id go with the 7950, do like the Nvidia cards but i really hate there prices :\
Plus it seems most members here are all in to Oc hardware any way so id say go the cheaper option if your planning on Oc it.
7950 is better value @ around £240, your getting double the vram and better overclocking potential..
Much appreciated all. I won't be clocking now, but in the future very possibly.
