**TODAY ONLY! 21/07/2014** EpicGear Hybrid Gaming Surface & Akasa AK-876 AMD CPU Cooler
OcUK Staff
4 Feb 2013
EpicGear Hybrid Gaming Surface - Medium @ £4.99 inc VAT
Epic Gear Gaming Mousepad - Hybrid Pad Specifically Designed for the HDST Gaming Mice.
- Dimensions: 350 x 250 x 3mm
- Composite Fabric
Only £4.99 inc VAT.
ORDER NOW
________
Akasa AK-876 AMD CPU Cooler @ £3.95 inc VAT
The low noise AK-876 utilizes U-shape heatpipe technology for rapid and even heat transfer. A copper base is used for maximum heat absorption; three precision embedded copper heatpipes ensure high speed heat transfer and 45 aluminium fine fins for ultimate heat dissipation. 4-pin fan connector with 3-pin compatibility allows for fan power management via PWM, Cool’n’Quiet and auto fan control. Low noise 92mm round frame fan provides efficient and quiet cooling. A steel cam-lever retention clip is used for safe and easy attachment. The specific fan positioning enhances the VRM cooling and thermal compound is pre-applied. The AK-876 can be assembled horizontally or vertically as the heatpipes work independently of installation direction.
- Socket Type: AMD 754 / 939 / 940 / AM2 / 1207FX
- Dimensions: 138mm x 105mm x 58mm
- Fan Dimensions: 92mm x 92mm x 25mm
- Fan Connector: 4-Pin / 3-Pin (PWM)
- Fan Speed: 600 - 2500 RPM
- Airflow: 10.56 - 47.68 CFM
- Noise Level: 17.0 - 30.0 dB
Only £3.95 inc VAT.
ORDER NOW
Lol...the Akasa 876 CPU cooler...still going at OCUK, I bought one for my 2009 era Phenom II rig, not a bad little thing, kept my 550 @3.8Ghz, 1.47vlts below 60c through numerous LinX runs and the hottest of summer temperatures, sadly unlocking the extra cores meant it couldn't cope with anything other than stock 3.1Ghz.
Still for 4 quid mate it's not bad
