Today, save yourself £10 on an LG Blu Ray drive which will enable you to watch 1080p quality Blu Ray films right on your PC. LightScribe gives you the added feature of etching customized labels onto a special coated LightScribe discs.
We also have the best looking self-contained watercooling kit which is now available from no other than Intel. Developed with the teams behind the Corsair liquid cooling solutions, this cooler isn't one to give a miss.
LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (OEM) @ £59.99 inc VAT
Read and write Blu-ray discs at 10x with the BH10LS38 Blu-ray rewriter that allows you record files, photos, or business documents onto a single dual layer BD-R Blu-ray disc. Play HD content from BD Video discs or record up to nine hours of high definition video. SATA interface technology allows for easier integration and ultimately faster performance while LightScribe gives you the added feature of etching customized labels onto a special coated LightScribe discs. Get into the Blu with the BH10LS38 by LG.
Write Speeds
- BD-R: 10x
- BD-RE: 2x
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 10x
- BD-R: 6x
- BD-R: 6x
- BD-RE: 8x
- DVD-ROM:16x
- DVD-R: 12x
- DVD-RW: 10x
- DVD+R: 12x
- DVD+RW: 10x
- DVD-RAM: 5x
- DVD-Video: 8x
- CD-R/RW/ROM: 40x
- CD-DA: 40x
- 80 mm CD: 16x
Only £59.99 inc VAT.
ORDER NOW
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155/1156//1366/2011) @ £67.98 inc VAT
Intel teamed up with no other than Asetek to offer the Intel RTS2011LC self contained water cooler kit. Asetek have been making these type of kits for a while and was behind the Corsair H50 and H70 as well as the Antec Kuhler 620 and 920.
- Socket LGA1155/LGA1156//LGA1366/LGA2011
- Fan Speed: 800-2200 RPM (4 wire PWM)
- Fan Dimensions: 120 mm x 120 mm x 25 mm
- Fan Airflow: 74CFM
- Unit Noise Level: 21dBA@800 RPM / 35dBA @ 2200 RPM
- Radiator Dimensions: 150mm x 118mm x 37mm
- Pump Z-Height: 33mm
- Total Thermal Solution Weight: 820 grams
- Cooling Liquid: Propylene Glycol
- Thermal Interface Material: TC-1996
Only £67.98 inc VAT.
ORDER NOW
Write Speeds
- BD-R: 10x
- BD-RE: 2x
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 10x
- BD-R: 6x
- BD-R: 6x
- BD-RE: 8x
- DVD-ROM:16x
- DVD-R: 12x
- DVD-RW: 10x
- DVD+R: 12x
- DVD+RW: 10x
- DVD-RAM: 5x
- DVD-Video: 8x
- CD-R/RW/ROM: 40x
- CD-DA: 40x
- 80 mm CD: 16x
ORDER NOW
ORDER NOW
