TP-Link 300Mbps Mini Wireless N USB Adapter (TL-WN823N) @ £9.49 inc VAT
300Mbps Wireless N Speed – Extend Wireless Coverage
With wireless speeds of up to 300Mbps and advanced MIMO technology, the TL-WN823N provides you with a fast, reliable wireless connection for lag-free online gaming and video streaming. Better still, TL-WN823N achieves the best performance with wireless N devices, but also works seamlessly with existing IEEE 802.11b/g networks.
SoftAP Mode – Easy Wireless Internet Sharing
SoftAP Mode enables this tiny adapter to work as a virtual wireless Access Point. Once applied, this mode allows users to easily turn their existing wired connections to a laptop or PC into wireless and share it with other Wi-Fi enabled devices like laptops, smartphones or tablets.
One Button Security Setup
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WN823N features Quick Security Setup that allows users to almost instantly setup their security simply by pressing the WPS button to automatically establish a WPA2 secure connection, more secure than WEP encryptions. Not only is this faster than normal security setups but more convenient in that users needn't remember a password!
Easy to Use
Included in the resource CD, TP-LINK's optimized configuration utility can help users complete the entire software installation and wireless network settings in just few minutes. Its simple and user friendly interface makes TL-WN823N so convenient that even novice users can get started quickly and establish their connections effortlessly.
Features: -
- 300Mbps wireless speed ideal for smooth HD video, voice streaming and online gaming
- Mini-sized design for convenient portability with a reliable high performance
- SoftAP Mode – Turn a wired internet connection to a PC or Laptop into a Wi-Fi hotspot
-Easily setup a secure wireless connection with one-touch WPS button
- USB 2.0
- Wi-Fi Protected Setup (WPS) Button
- Dimensions:- 1.54(W) x 0.72(D) x 0.31(H) inches.
Only £9.49 inc VAT.
ORDER NOW
_______
BitFenix Flo Gaming Headset, SofTouch - White @ £24.95 inc VAT
From the BitFenix Design Lab comes Flo™ – the premium PC headset made to move with you. Combining
studio-engineered sound and signature BitFenix design, Flo delivers the audio you need at the PC and the
styling you want on the road. Precision-tuned acoustic chambers equipped with 40mm Neodymium drivers ensure balanced, high definition sound whether you're fragging the opposition, or listening to your favorite tunes on the go. Simply plug in the flexible microphone to dominate your opponents, and then detach it to rock to your own beats during your victory lap.
Flo is designed with a clean, stylish, and modern look, with multiple color options and signature BitFenix SofTouch™ Surface Treatment for a premium matte look and soft feel. The self-adjusting headband contours to the shape of your head and provides optimal support.
SoftFeel™ earcups provide supreme comfort during long listening sessions, and aside from providing
astonishing durability, the steel frame structure gives optimal pressure for maximum noise attenuation.
Features:-
- Signature BitFenix Design – Clean and modern look you'll want to wear away from the PC
- Superior Sound – 40mm Neodymium drivers with precision-tuned acoustic chambers
- Outstanding Comfort – SoftFeel™ Earcups with self-adjusting headband
- Maximum Durability – Steel frame construction for a design that lasts
- Excellent Ergonomics – In-line remote and removable/flexible microphone
- Choose Your Own Style – Four vibrant color options available
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
Specification:-
- Materials Steel, Plastic, SofTouch™ Surface Treatment, SoftFeel™ Earcups
- Acoustic Design Dynamic, Closed-back
- Driver 16ì, Neodymium magnet, Ö40mm
- Sensitivity 96db /1mW
- Frequency Response 20hz-20khz
- Rated Impedance 68 Ù
- Earpads SoftFeel™
- Headband Pressure Approximately 5N
- Cables 1m (3.3') and 2m (6.6')
- Connector Gold-plated Ö3.5mm stereo mini-plug with aluminum sheath
- Net Weight 200g
Only £24.95 inc VAT.
ORDER NOW
Easy to Use
Features: -
- USB 2.0
Only £9.49 inc VAT.
ORDER NOW
_______
Features:-
Specification:-
- Earpads SoftFeel™
- Net Weight 200g
ORDER NOW
