**Today Only 22/10/2011** Titan Spinosaur PC and Corsair 16GB RAM Kit
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Here are the latest and greatest Today Only offerings with £80 off the system and £24 off the memory kit.
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System @ £752.98 inc VAT
Stalking through the jungle, the "Titan Spinosaur" is master of all. Featuring the Intel Core i5 2500K overclocked to a ridiculous 4.60Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a choice of the latest DX11 graphics cards, equip yourself ready for the hunt ahead with the best offering from both Nvidia and ATI.
Why You Should Buy This System
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
System Specification
- Case: Antec 300 Case with Purple LED Fans
- Power Supply: OCZ ZS 750w PSU
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: OcUK H2 Flo CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Choice of DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Heighten your gaming experience with the "Titan Spinosaur", stalk your prey down and demolish the competition. Equipped with either ATI or Nvidia, become a champion.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £832.98 Inc. VAT
Only £752.98 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9) @ £75.98 inc VAT
CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each four module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Four matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £99.98 Inc. VAT
Only £75.98 inc VAT.
ORDER NOW
wow..I never thought 16Gigabyte of ram would ever get that cheap..lol.Just a shame I bought an 8gb kit not long back :S
I think you should do a deal on the low profile and normal heatsinks.
Id like to have a set, but my cooler will cover the first two slots :(
