Today only deals, limited deal stock units
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £24.98 inc VAT
Excessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.
- Compatible with Intel and AMD systems
- Three 8mm copper direct-contact heatpipes
- Aluminum fins
- Low-noise, low-vibration 120mm fan mounted on rubber studs
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want
- Air flow: 50 - 61 CFM
- Noise level: 26 - 31.5 dBA
- Two-year warranty
Only £24.98 inc VAT.
ORDER NOW
Plantronics GameCom 777 USB 7.1 Surround Sound Headset @ £42.98 inc VAT
This open-eared headset with 7.1 Dolby Headphone technology gives you an unparalleled audio advantage that lets you hear your opponents before you see them. Connect with the Dolby USB sound card for a true 7.1 experience. But if needed, an analogue connection is also provided. Stay comfortable with a lightweight frame and specially designed ear pods that redistribute pressure. When you’re ready to fire off orders, unveil the hidden, noise-cancelling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls.
- Dolby Headphone technology delivers a 5-channel audio experience.
- Dolby USB sound card is the only way to get the 7.1 experience. If needed, an analog connection is also provided.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-grade design and extra-strength cables make your hardware hardcore.
Only £42.98 inc VAT.
ORDER NOW
- Aluminum fins
- Two-year warranty
ORDER NOW
ORDER NOW
