On Today Only we have 2 fantastic headsets, check them out.
Razer Tiamat Expert 2.2 Analog Gaming Headset @ £49.99 inc VAT
The Razer Tiamat headset range is the pride of our audio engineering, built to deliver the most powerful, clear and accurately produced positional audio gamers will ever need for the competitive edge
Optimized positional audio
The audio drivers in the Razer Tiamat 2.2 have been designed to simulate a three-dimensional audio effect for deeper immersion with your games. Get a sense of position and depth in your surroundings, so you can hear how far and where exactly an opponent is by his gunfire or footsteps, for the tactical advantage.
Two discrete sub-woofer drivers for heavier-duty bass
The Razer Tiamat 2.2 houses not one, but two sub-woofer drivers for stronger bass support and overall audio performance so you are closer to the action and further from thin, mediocre basslines.
Maximum comfort, maximum durability
The Razer Tiamat 2.2’s sturdy construction and snug-fit padded leatherette ear cups ensure extended headset life and ultimate comfort so you can keep terrorizing noobs during those hardcore marathon gaming sessions..
Only £49.99 inc VAT.
ORDER NOW
SteelSeries Siberia V2 Full-Size USB Gaming Headset - Frost Blue (51125) @ £54.00 inc VAT
Welcome to Siberia. An incredible soundscape in a lightweight over-the-head suspension design combined with brilliant blue illumination and the ability to customize what you're hearing through an easy-to-configure software suite. This is the SteelSeries Siberia v2 Frost Blue Headset. -Programmable Frost Blue illumination: on/off, pulsation, intensity and trigger-modes -Integrated USB powered sound card provides rich, detailed soundscape -Pull-out, Active Noise-Canceling Microphone System -50mm drivers with large, comfortable earcups -Inline controls for easy access to volume and microphone mute -Powered by SteelSeries Engine, w. customizable equalizers and profiles -PC/Mac compatible (SteelSeries Engine for Mac coming 2012) Stay Frosty. Marketing Features: -Programmable Frost Blue illumination: on/off, pulsation, intensity and trigger-modes -Integrated USB powered sound card provides rich, detailed soundscape -Pull-out, Active Noise-Canceling Microphone System -50mm drivers with large, comfortable earcups -Inline controls for easy access to volume and microphone mute -Powered by SteelSeries Engine, w. customizable equalizers and profiles -PC/Mac compatible (SteelSeries Engine for Mac coming 2012)
• Cord Length (m) - 3
• Cord Length (ft) - 9
• Wireless - No
• Connection Type - USB
• Documentation Type - Quick Start Guide
• Sample of Documentation - Attached
• Color - Frost Blue
• Type of Ear Cushion - Noise Reducing Foam
• Dismantle for Travel - No
• Headphone Style - Over the Head
• Frequency Response (Hz) - 18 – 28000
• Magnet Type - Neodymium
• Microphone Frequency Response (Hz) - 50 - 16000
• Microphone Pick-up Pattern - Uni-directional
• Microphone Sensitivity (dB) -38
• Headphone Impedance (Ohm) - 32
• Illumination - Yes
• Profiles Available - Yes
• Finish - Glossy
• Driver Size (mm) - 50
• Microphone Location - Retractable
• Microphone Noise Cancellation - Yes
Only £54.00 inc VAT.
ORDER NOW
ORDER NOW
• Wireless - No
• Finish - Glossy
ORDER NOW
