**Today Only 23/07/2012** NZXT Phantom Enthusiast USB3.0 Full Tower Case & Samsung 256GB SSD 830 No
22 Mar 2011
Cheshire
NZXT Phantom Enthusiast USB3.0 Full Tower Case - White @ £94.98 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Was £109.99 Inc. VAT
Only £94.98 Inc. VAT
ORDER NOW
Samsung 256GB SSD 830 Notebook/Apple Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC256N/EU) @ £147.98 inc VAT
Outstanding Performance in Multi-Tasking
Samsung’s fast random read speeds (up to 80,000 IOPS) maximize performance* when it matters most. A Samsung SSD is the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
Lightning Fast Speed. At Your Command
The 830 Series’ 520MB/s sequential read speed provides lightning fast access to your files, loading large multimedia files quickly and smoothly.
Sustained Performance and Unrivaled Reliability
Samsung SSDs are designed and build completely in-house. The Samsung SSD 830 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially- engineered wear-leveling and garbage collection algorithms.
A Complete, User-Friendly Solution
The Samsung SSD 830 series is available with a user-friendly installation kit, including a full version of Norton Ghost, an interactive installation guide, and premium installation tools for both desktops and laptops.
Toggle DDR NAND Flash
Use the wider image option when adding this feature. We would like to capture all of the data represented on this specific feature image. However, do not use this feature image in this document, use the actual image in images folder. Samsung’s 20-nanometer-class toggle DDR NAND Flash chips enable data transfer rates of up to 133 megabits per second (Mbps)-more than three times faster than conventional (40 Mbps) single-date-rate (SDR) NAND Flash chips.
3-core ARM9-based MCX Controller
While most SSD makers rely on generic, dual-core controllers, Samsung has developed its own proprietary, triple-core MCX controllers that excel in multi-tasking and help to assure stead performance over time. Based on an ARM9 controller, its three CPU cores can execute multiple instructions such reading data, writing data and optimization.
256MB DDR2 DRAM Cache Memory
256MB of DRAM cache memory helps maintain stable random read performance, even if the access range is increased.
The Samsung SSD 830 Series boasts superior random read speeds (up to 80,000 IOPS) and faster
sequential read and write speeds (up to 520 MB/s & 400 MB/s respectively). It’s the ideal solution for
Samsung’s SSD Magician software eliminates the confusion and uncertainties of SSD management,
making it simple for users to maximize the performance and lifetime of their Samsung SSD. The
software helps to maintain the SSD at its peak condition, giving you the same great performance and
reliability throughout the life of your PC. In addition to its performance maintenance features, SSD
Magician also provides system information and facilitates performance benchmarking, performance
optimization, OS optimization, firmware updates, secure erasing, and over provisioning.
- Capcity: 256GB
- Dimensions (LWH): 100 x 69.5 x 7 (mm)
- Samsung Toggle NAND
- Sequential Read: 520MB/s
- Sequential Write: 400MB/s
- 4K Random Read: 80,000 IOPS
- 4K Random Write: 36,000 IOPS
- Warranty: 3 years
- Norton Ghost
- SSD 2.5"-3.5" tray
Was £173.99 Inc. VAT
Only £147.98 Inc. VAT
ORDER NOW
ordered another 830 for my growing and now upto 1000mb/s steam games drive lol now I can install some more of my faves as I have 512gb in raid 0 :D Better back it all up to the 2TB slowbie backup drive tonight and get downloading extra games. Gonna move the agility 3 boot drive over to the intel sata 2 port and keep the 2 sammys on the intel 6gbps ports for the speeds. When I get the 3rd one next month I'll kinda need to move all 3 sammys to the intel sata 2 ports and the agility back to the sata 3, but by then I'll have 3 drive raid 0 so the combined speed of 3 sata 2 ports will exceed 1 sata 3 drive.
Yeah what's with the vertex 4 it is listed slower than the other top drives but costs a bit more and does seem to have some cool tech inside it but is it actually better than the 830 series?
