**TODAY ONLY! 23/09/2014** Corsair Flash Voyager Slider 16GB & Kingston HyperX Fury 240GB
OcUK Staff
4 Feb 2013
Corsair Flash Voyager Slider USB3.0 Pen Drive - 16GB (CMFSL3B-16GB) @ £8.48 inc VAT
Flash Voyager Slider combines high performance and capless convenience at an affordable price. This flash drive has USB 3.0 speed and full USB 2.0 compatibility. Just plug it in and it works, with Windows, Mac OS X and even Linux. The Flash Voyager USB 3.0 is backed by Corsair, a respected name with a passion for quality and customer service.
Unformatted Capacity: 16GB
Max Read (USB 3.0): 70 MB/sec
Max Write (USB 3.0): 20 MB/sec
Interface Type: USB 3.0
Shock: 40G
External Dimensions: 70mm x 24mm
Only £8.48 inc VAT.
ORDER NOW
______
Kingston HyperX Fury 240GB 2.5" SATA 6Gbps Solid State Drive (SHFS37A/240G) @ £79.98 inc VAT
High performance. Low price. You game?
HyperX® FURY solid-state drive delivers impressive performance at an affordable price, to get you into the game faster and improve your gameplay. It features a slim 7mm form factor and SandForce® SF-2281 controller with SATA Rev 3.0 (6Gb/s) performance for faster system boot up, application loading and file execution plus faster map and level load time. Its synchronous NAND allows for higher and consistent drive performance. So you're not only in the game, you're winning it.
HyperX FURY SSD is available as a stand-alone drive and is easy to install. This cost-e cient upgrade is less disruptive than buying a new system to increase performance. The new FURY entry-level product line from HyperX includes memory and SSDs and is designed for gamers, enthusiasts and system Integrators, who can now have consistent HyperX branding for their gaming PCs.
Built with Flash memory, HyperX FURY SSD has no moving parts and is cooler, quieter and more shock- and vibration-resistant than traditional hard drives, making it the ideal hard drive replacement. It’s backed by a three-year warranty and free technical support.
SandForce controller with SATA Rev 3.0 (6Gb/s) performance
Read/write speeds of 500/500 MB/s
Features synchronous NAND for consistent high SSD performance
Faster system boot up times, application loading & file execution
Faster map and level load times in game with increased frames per second
Baseline performance Compressible data transfer (ATTO) All capacities: 500MB/s read and 500MB/s write. Incompressible data transfer (AS-SSD and CrystalDiskMark)
240GB — 470MB/s read and 220MB/s write
Maximum 4k Read/Write
240GB — up to 84,500/ up to 41,000 IOPS
Random 4k Read/Write
240GB — up to 22,500/ up to 41,000 IOPS
PCMark® Vantage HDD Suite Score
240GB — 60,000
PCMark 8 storage bandwidth
240GB – 180 MB/s
Only £79.98 inc VAT.
ORDER NOW
Hi
How reliable are SSD's these days.......would you use one in a work laptop?
I have an i5 laptop everything is great except the slow hard drive.
I only buy SSD now. Very reliable IMO. Usual caveats, back up important data.
Seems a good deal, around 30p per GB is what I look for.
Indeed SSD is the way to go. The USB drive is very good too. I have the 64 GB version and it has given me Stirling service for months and months.
