Today Only, two simply fantastic deals to help you save money but also bringing you the ultimate performance. If your looking for products to bring you speed, look no further.
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) @ £93.99 inc VAT
The new 2.5" Crucial RealSSD C300 drive offers mobile and desktop users scorching-fast read speeds of up to 355MB/s. And because it has no moving parts, you will also enjoy a quieter, cooler, and more durable storage solution. Designed with high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management and the new SATA 6Gb/s interface, these drives dramatically improve data transfers for bandwidth-demanding applications like audio and video. The improvement in boot time and application load times push performance to new levels at the desktop too. You will experience improvement across a variety of common tasks such as viewing and editing photos, video, music and other media, gaming, communications, productivity and security.
- Capacity: 64GB
- Cache: 128MB
- Controller: Marvell 88SS9174
- Read: Up to 355MB/sec
- Write: Up to 70MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA 6Gbps
- Low Power Consumption
- Shock Resistant
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £93.99 inc VAT.
ORDER NOW
OCZ Reaper Low-Latency 4GB (2x2GB) DDR3 PC3-12800C6 1600MHz Dual-Channel (OCZ3RPR1600C6LV4GK) @ £75.19 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements and tight CL6 timings at 1600MHz.
Developed for speed-hungry enthusiasts and gamers with overclocking on the mind, these new OCZ modules were engineered with the same performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for desktops.
OCZ DDR3 PC3-12800 Reaper Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety Reaper HPC Heatsink for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1600MHz DDR3
- CL 6-8-6-24 (CAS-TRCD-TRP-TRAS)
- Available in 4GB optimized kits
- Unbuffered
- Lifetime Warranty
- 1.65 Volts
Only £75.19 inc VAT.
ORDER NOW
- Capacity: 64GB
- Cache: 128MB
- Shock Resistant
- Warranty: 3 Years
ORDER NOW
- 1600MHz DDR3
- Unbuffered
- Lifetime Warranty
- 1.65 Volts
ORDER NOW
