**Today Only 24/01/2011** Corsair Vengeance 12GB 1600Mhz & Arctic Cooling Freezer 13 High Performanc
22 Aug 2010
Today Only, we have 15 units of Corsair Vengeance 12GBD 1600MHz DDR3 Memory for just £137.99 inc. VAT. The Corsair Vengeance memory has been thoroughly tested with the new Intel Sandybridge CPUs and is 100% compatible. Vengeance memory modules provide users with outstanding memory performance and stability.
We also have 20 units of Arctic Cooling Freezer 13 High Performance CPU Cooler for just £21.98 inc. VAT. The Freezer 13 carries on the legacy of providing efficient and low noise CPU cooling solution for enthusiasts.
Arctic Cooling Freezer 13 High Performance CPU Cooler (Socket LGA775/1155/1156/1366/939/AM2/AM2+) @ £21.98 inc VAT
Following the footsteps of the renowned Freezer 7 Pro Rev.2., the Freezer 13 carries on the legacy of providing efficient and low noise CPU cooling solution for enthusiasts. Featuring a whisper-quiet 92 mm PWM fan, aluminum fins with heatpipes, the Freezer 13 can perform its duties with any high-performance CPU.
- Heatsink Dimension: 123mm x 96mm x 130mm (L x W x H)
- Heatsink Material: Aluminum fins x 45, thickness 0.5mm
- Fan: 92mm, 600 – 2000 RPM (controlled by PWM)
- Air Flow: 36.4 CFM
- Max. cooling capacity: 200 Watts
- Bearing type: Fluid Dynamic Bearing
- Weight: 695g
- Compatibility: Intel 775/1155/1156/1366 AMD 939/AM2/AM2+/AM3
Only £21.98 inc VAT.
ORDER NOW
Corsair Vengeance 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel Kit (CMZ12GX3M3A1600C9) @ £137.99 inc VAT
CORSAIR high performance Vengeance memory module 12GB (3x4GB) 1600MHz 9-9-9-24, CL9, 1.5V for motherboards using Intel triple channel processors. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each three module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 6144 Megabytes of DDR3 memory
- Three matched 4GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £137.99 inc VAT.
ORDER NOW
OP said:
This Weekend Only, at the best price in the UK we have 30 units of Logitech G27 Racing Wheel for just £212.99 inc. VAT. Compatible with PC / PS2 / PS3 the Logitech G27 Racing Wheel brings you closer to the extreme driving action. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action.
We also have 20 units of Coolermaster CM-690 II Lite Dominator Case for just £53.99 inc. VAT. The CM 690 II Lite raises the bar again, but with value for money, with practical improvements over the top-selling CM 690.
whoops? :p
