**TODAY ONLY! 24/01/2014** NZXT Hale Power 90+ 1000W '80 Plus Gold' & MSI Radeon R9 280X Gaming Edit
OcUK Staff
4 Feb 2013
NZXT Hale Power 90+ 1000W '80 Plus Gold' Modular Power Supply @ £136.99 inc VAT
NZXT introduces the 80+ gold certified HALE90 series built from the ground up specifically customized for gamers and enthusiasts and offers incredibly efficient operation that will meet the needs of even the most power hungry enthusiasts.
• 80+ Gold certified: The HALE 90 series from NZXT operates at ultra high efficiency, at 20%, 50% and 100% loads, efficiencies are 87%, 90%, and 87% respectively.
• Single140mm two ball-bearing fan operates with minimal noise even at full load. Maximum decibel levels are 20db for wattages between 550-750W and 30db for 850W and above.
• Strong Single Rail Design: A single +12V rail provides stability and ease of use making the most out of your power supply. Offers stable & clean current delivery under heavy load.
• Modular cable design: Modular cable design allows the user to pick and choose which cables they want to use, optimizing cable management and airflow inside the chassis. Flat cables allow for easier routing and bending inside the computer chassis during wire management.
• Hybrid LLC resonant Topology circuitry allows the HALE series to create highly efficient power supplies ranging from 550W-> 1000W.
• Full range Design from 100V – 250V with Active PFC.
• 100% Japanese Capacitors: High quality components for longer life time and better reliability.
• Latest CPU support for all the latest INTEL and AMD CPUs like Corei7, i5, AMD Phenom II X4, X3.
• Latest GPU support, ideal for latest DX11 GPUs and comes with 8pin and 8(6+2) pin PCI-E connectors.
• Large tower support: The Hale Series of power supplies have extended 8pin CPU connectors for wire management in large cases which have PSUs mounted at the bottom.
• Compliance with ATX 12V v2.2, EPS 12V v2.91, and SSI EPS 12V v2.92 Specifications.
• Environmentally Responsible: Consuming less than 1W during shut off status Complies with the newest EuP ( Energy-using Products) requirements and USA Energy star standards.
• Continuous Power: The HALE 90 series listed wattage is the continuous operating wattage.
• Keeping it safe: The HALE series offers over voltage, current, power, under voltage, and short circuit protection. The power supply will automatically shutdown to prevent any damage to your system or misuse.
• Warranty: 5 Years
Only £136.99 inc VAT.
ORDER NOW
_____
MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
R9 Series Graphics
The AMD Radeon™ R9 280X graphics processor harnesses visionary GCN Architecture. This GPU is primed to enable astonishing performance and breathtaking image quality, making it a top choice for gamers who expect the best.
LET THE GAMES BEGIN
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
MILITARY CLASS 4 COMPONENTS
Military Class 4 is the next step in high quality components. The Hi-c CAPs, Super Ferrite Chokes and Dark CAPs will make sure that your PC runs more stable under extreme gaming conditions.
ADVANCED TWIN FROZR IV
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked off the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means.
AFTERBURNER
MSI Afterburner has quickly become the favorite overclocking software for media, overclockers and end-users. Because of its simple interface, it's easy to learn, but it packs a lot of powerful features like an integrated benchmark utility called Kombustor that can check your system performance in benchmarking mode, or run as a stability test.
GAMING APP
EASY TUNE, EASY PLAY - OC Mode, Gaming Mode and Silent Mode available at a click of a button. You decide!
PREDATOR
A built-in screen and video capturing tool named Predator which captures your screen as still images or videos with the push of a button and allows you to capture and record your coolest, goofiest and most awesome gaming moments on your PC!
Ultra Resolution Gaming
Leave HD in the dust by gaming on displays much, much larger. Whether using a 4k monitor or combining multiple HD monitors, you’ll get an expansive experience that’s truly out of sight.
GCN Architecture
Primed to enable astonishing performance and breathtaking image quality, making it a top choice for gamers who expect the best.
AMD CrossFire™ Technology
With outstanding performance scaling, a system equipped with AMD CrossFire™ technology keeps you fragging while everyone else is reaching for an upgrade.
AMD Eyefinity Technology
Enjoy the ultimate immersive gaming experience with innovative “wrap around” multidisplay capabilities.
AMD HD3D Technology
Play 3D games, watch Blu-ray 3D videos, and edit 3D photos on your 3D monitor, TV or projector.
AMD App Acceleration
Improve performance of everyday tasks such as Web browsing, office applications and video rendering.
AMD PowerTune Technology
Enables intelligent power monitoring to enable higher clock speeds and better performance in your favorite games.
AMD ZeroCore Technology
Allows your AMD Radeon™ GPU to consume virtually no power when in idle state.
Specifications
Interface:
PCI-e 3.0 (backwards compatible with 2.0)
Core Speed:
1000MHz (1050MHz Boost Speed)
Memory Buffer:
3GB GDDR5
Memory Speed:
6000MHz
Memory Interface:
384-bit
Connectivity:
1x DVI, 1x HDMI, 2x Mini-DP
Stream Processors:
2048
HDCP Support:
Yes
Max Resolution:
4096x2160
DirectX Support:
DirectX 11.2
CrossFire:
Yes
Monitor Support:
Up to 4 displays
Power:
1x 6-Pin + 1x 8-Pin (250W TDP)
Dimensions:
269 x 128 x 34 mm
Only £229.99 inc VAT.
ORDER NOW
Is there a list of modular cables the HALE comes with? Ideally I want to know which PCI-E power cables it comes with (8-pin and 6-pin) as I'm looking to run 2 or more cards...
Also are these Seasonic based? It'll be to replace a PC Power & Cooling 600W that I've overloaded a couple of times (and had to reduce my overclocks) when mining...
Yeah the PC Power & Cooling is Seasonic and very impressive (held my 2700k @ 4.8ghtz and 2x 7950's @1200/1350 for gaming easily... Only when I started mining did it struggle!)
I figure the HALE 1000W is a much better buy than going for the 850W for £130! ;)
Dimensions wise (180 x 150 x 86) it's not much bigger than my PC P & C (150 x 150 x 86) and less than a Corsair AX1200 (200 x 150 x 86) which I found too big to mount a lower fan in my Fractal R4 (for secondary GPU cooling)... Fingers crossed eh! ;)
Also being Gold rated (my current is Bronze) will mean it won't struggle as much at high load when mining (and generate less heat)!
SOLD! :D
Would I be able to slap the waterblovk of my deceased 7970 onto the 280X?
Seems I have been shafted by a seller on teh bay on a replacement 7970 so this makes better sense as is only £30 more than I paid for the card on there and is brand spankers (may muck up th ewarrenty by slapping on the waterblock though)
