Zalman ZM 1250W '80 Plus Platinum' Modular Power Supply @ £124.99 inc VAT
Thanks to a new design the ZM1250 efficiency of the unit is very high 89-93% (20-100% load) top efficiency. It also uses a powerful and highly reliable DC-DC module (to increase performance and reliability), along with full bridge and LLC resonant circuits which lowers switching losses, boosts efficiency and is guaranteed to deliver 1250w continuous power even in a warm case (up to 50 °C).
The ZM12050-Platinum boasts an ultra-quiet 140 mm fan, the speed of which is controlled by the Smart Fan Control system. This means that the fan won't spin at all until the PSU is under 40% load and this minimises audible noise ensuring the PSU remains as quiet as possible during operation.
Component quality is always vital for the longevity of a PSU and Zalman are now using high quality Japanese capacitors. These offer greater stability at higher operating temperatures, frequencies and currents giving a high powered PSU like the ZM12050-Platinum the edge in reliability and performance.
It also incorporates heavy-duty protection circuitry which guards against over-current, over-power, over-voltage, over-temperature, under-voltage and short circuits.
As with most modern PSU designs, this unit features a modular cable system. This allows you to remove those cables which aren't needed, improving the appearance, maintainability and airflow inside your PC case. A further benefit is that all the cables themselves are flat which makes them less bulky and cable management even easier.
Eight PCI-E cables allow this PSU to support 4-way SLI and CrossFireX configurations making this the perfect PSU for high-end gaming enthusiasts.
- 80 PLUS Platinum certified PSU 89-93%
- Smart Fan control system - Fanless up to 40% load
- Guaranteed to provide 1250W continuous power
- High quality 105°C Japanese capacitors
- Multi-GPU ready for 4-Way CrossFireX and SLI
- Full Bridge and LLC resonance circuit with DC-DC module
- Smart fan control system
- Meets ErP 2010 Lot6 standby power standards
- Safety / EMI Approvals, CE, FCC, UL, CB, KC certified
- 5 Year warranty
Only £124.99 inc VAT.
ORDER NOW
______
Prolimatech 48 CPU Cooler - 92mm @ £14.99 inc VAT
The Basic 48 features three high quality heat pipes and one PWM 92mm Hydro-Dynamic bearing fan. Its small size is well suited for small cases. Intel and AMD compatible.
The Basic Series offers competitive solid performance at a budget level price! They are designed to be affordable while still maintaining the reliable quality you've come to expect from us. They are an excellent option for replacing stock coolers in any system, for improved cooling, quieter operation, and even overclocking! Check out the 5 different models to find the perfect cooler for your hardware, be it small media centers to massive hungry processors!
- Material: Nickel plated copper (heat pipes), Copper (base plate), aluminum (blades, base plate)
- Heatpipes: 3x Ø 6 mm
- Fan: 1x 92 mm
- Connector: 4-pin PWM
- Speed: 1500-2000 r / min (+ / - 10%)
- Dimensions: 100 x 125 x 55 mm (W x H x D)
- Weight: about 309 g
Only £14.99 inc VAT.
ORDER NOW
- 5 Year warranty
ORDER NOW
______
- Fan: 1x 92 mm
ORDER NOW
