Today Only, two great deals which brings great performance without you having to spend too much!
Asus GeForce GTX 460 1024MB DirectCU TOP GDDR5 PCI-Express Graphics Card @ £152.74 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- ASUS Exclusive DirectCU Thermal Solution: Three 8mm flattened copper heat-pipes contact GPU directly and reach up to 20% COOLER than generic GeForce GTX460
- Over-clocked with 775 MHz engine clock for reaching 115% performance
- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
- Core Clock: 775MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1550MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Only £152.74 inc VAT.
ORDER NOW
Biostar G31D-M7 Intel G31 (Socket 775) DDR2 Motherboard @ £26.98 inc VAT
The classic G31 Intel Chipset provides excellent value for money, reliability and 1080P video playback via the Onboard graphics.
- CPU Support: Intel® Core™2 Duo Processor, Intel® Pentium® Dual-Core Processor, Intel® Celeron® Dual-Core Processor, Intel® Celeron® Processor 400 Sequence
- Maximum CPU TDP (Thermal Design Power) : 65Watt
- FSB: Support FSB 800/1066/1333MHz
- Memory: Support Dual Channel DDR2 667/800 MHz, 2 x DDR2 DIMM Memory Slot, Max. Supports up to 4GB Memory
- Expansion Slot: 1 x PCI Slots, 1 x PCI-E x16 Slot,
- Storage: 2 x SATA2 3Gb/s Connector, 1 x IDE Connector
- USB: 4 x USB 2.0 Port,1 x USB 2.0 Header
- LAN: Realtek RTL8102EL - 10/100 Controller
- Onboard Graphics: Intel Graphics Media Accelerator 3100 On Board Graphic Max. Share Memory 256MB
- Audio: Realtek ALC662 6-Channel HD Audio
- Rear I/O: 1 x PS/2 Mouse, 1 x PS/2 Keyboard, 4 x USB 2.0 Port, 1 x VGA Port, 1 x RJ-45 Port, 3 x Audio Connector
- Accessories: 2 x SATA Cable, 1 x I/O Shield, 1 x CD Driver, 1 x User Manual
- Micro ATX Form Factor Dimension: 22.5 cm X 17 cm ( W x L )
Only £26.98 inc VAT.
ORDER NOW
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
ORDER NOW
ORDER NOW
