**Today Only 24/11/2011** Seagate Barracuda 7200.12 1TB £79.98!!! & EK H3O Watercooling Kit £112.98!
22 Aug 2010
Today only we have two fantastic products. A 1TB HDD which is only ONE ORDER PER PERSON due to the flooding disasters we need to make sure everyone gets a chance of grabbing one at this fantastic price.
We are also featuring a custom Watercooling in a box! The Ideal solution for a low noise system.
Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) @ £79.98 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 1TB of high-performing, eco-friendly digital storage.
- Capacity: 1TB
- Cache: 32MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 3 Years
Only £79.98 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme LT 120 **2011 Compatible** @ £112.98 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
EK have stepped in and solved this problem. With each EK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike, transform your computer system
All of these kits offer the new EK Standard EN Nickel Plating method which ensures the highest quality nickel plating finish on your water blocks.
Overclockers UK recommends the use of Distilled Water or Watercooling Fluid which is available on this web-store.
To make the kit functional, the user needs 1Litre of Coolant.
The EK-KIT H3O - Supreme LT 120 water cooling kit is basic kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme LT 120 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel 775, 1155/1156 and 1366 processors. The CPU block comes with an additional plate to allow use with AMD AM2 and AM3 sockets
Supreme LT block is one of most efficient CPU blocks (value for money) and offers very good thermal conductive performance and low restriction. Single EK-CoolStream RAD XT radiator will fit in majority of watercooling cases and will succesfully take heat out of your system. EK-DCP 2.2 pump has been also proven for some time now by water cooling community and allows adequate and optimal flow for your kit.
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is included)
It is reccomended to use this kit for CPU cooling only
Only £112.98 inc VAT.
ORDER NOW
