**Today Only 25/01/2011** Dell UltraSharp U2410 24" Midnight Grey & Corsair XMS3 8GB 1600MHz DDR3
22 Aug 2010
Today Only, we have 10 units of Dell UltraSharp U2410 24" Midnight Grey for just £437.99 inc. VAT. Experience astounding colour accuracy, precision and performance with a monitor which delivers reliable, true-to-life colour without the need for extensive calibration.
We also have 25 units of Corsair XMS3 8GB 1600MHz DDR3 for just £83.99 inc. VAT. Working in complete harmony with Intel Sandybridge CPUs the Corsair XMS3 runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at a lightning 1600MHz but with these tight latencies your system performance will rock.
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey (3yr On-Site Warranty) @ £437.99 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 80000:1
- Brightness: 400cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Only £437.99 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £83.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge compatible
Only £83.99 inc VAT.
ORDER NOW
The latest revision is best. Supposidly A05 shouldn't have the tint issues that some of the older revisions have, and I think it also has some minor other improvements over the original u2410.
I know that OcUK sold the original 2410, then at one point they had rev A02 for sale as well at the same time for a higher price, but now there is only 1 u2410 for sale and it has no mention of what revision it is.
