Today Only Deals
GamersWear PADMAN T-Shirt Black (L) @ £7.45 inc VAT
Hate to take your fingers off the control pad? This shirt lets you socialise without withdrawal symptoms.
Yellow print on a black T-shirt – the hit for every PadMan! Hem, sleeves and neckline are double stitched.
- Material: 100% cotton
- Weight: 190 g/m²
Only £7.45 inc VAT.
ORDER NOW
Avexir MPower Red Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CRR) @ £29.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower Red series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Red high performance heatspreaders
- Red LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-9-9-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £29.99 inc VAT.
ORDER NOW
- Weight: 190 g/m²
Only £7.45 inc VAT.
ORDER NOW
Features:
- Black PCB
- Lifetime Warranty
ORDER NOW
