- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
Today only we have 10 units of the HIS 7850 ICEQ Graphics card and 25 units of GeILs EVO Leggera Dual Channel memory Kit.
HIS HD 7850 IceQ 2048MB GDDR5 PCI-Express Graphics Card (H785Q2G2M) **OcUK Exclusive** @ £185.99 inc VAT
This HIS 7850 IceQ is a very special card and one which is exclusive to OcUK. Built using a 7870 PCB and the IceQ cooler from the 7870 this card has truly immense OC potential. Not only that but in its quiet mode the card operates in near silence. There is no better 7850 on the market and exclusively available from Overclockers UK.
With IceQ, the card is up to 20 °C cooler than the Reference Cooler. The super large 80 x 21.5mm single blower fan draws massive amount of cool air to cool the GPU directly. The fan is equipped with 2 ball bearing and is extremely durable with a life span of 50,000 hours! 4 wide heatpipes optimize cooling performance by removing heat from the core area. The extra large 35 x 30mm copper heatsink provides a large heat dissipation area. The card also features fan control and fan monitoring, you are able to read fan speed & Asic temperature from CCC or software. IceQ is one of the quietest coolers. The card is below 28dB dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working.
iTurbo is your software assistant to control your graphics card to be quiet, cool and experience overclocking by simply pressing the iTurbo Button! User Friendly Overclocking Software: Cooler, Quiter, OC!
iTurbo's Fan Control and Fan Monitoring allow easy adjustment of your card to its maximum cooling performance or to run your card quietly! Press iTurbo: OC Right Away! With the smart auto overclocking function, users can experience a slight performance boost for HIS selected graphic cards with just one click! Powerful Overclocking Software: Either you wish to unleash its full potential or to make it more environmental friendly, iTurbo is ready for you!
Features:-
- Core Clock: 860MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was £199.99 Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (GEL38GB2133C11DC) @ £35.99 inc VAT
“Leggera” means “light-weight” in the performance world, hence the name of GeIL’s low-profile heat-spreader solution for the DDR3 Hardcore Gaming Memory EVO Product Family - EVO LEGGERA.
EVO LEGGERA is equipped with the latest Leggera low-profile heat-spreader in Turquoise Blue finish, designed with GeIL’s MTCD - Maximum Thermal Conduction & Dissipation technology for enhanced cooling efficiency while maintaining a much more workable height for builds with oversized cooling solution from other PC components.
Speed of up to 2800MHz, like its counterpart in the EVO family, the EVO LEGGERA, is designed for all of the latest motherboard chipsets, including the Intel Z77 platform, for maximum performance and compatibility. The entire Series will also receive GeIL’s superior quality assurance standard of DBT – Diehard Burn-in Technology. EVO LEGGERA is the new performance benchmark with a low-profile heat-sink solution to provide users with aesthetics and functionality.
Features:-
- PC3-17000 2133MHz CAS 11-11-11-36
- Designed for PC
- GeIL EVO Leggera Design
- 1.50v VDIMM
- Limited Lifetime Warranty
Was £39.95 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Features:-
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features:-
- Designed for PC
- 1.50v VDIMM
Was £39.95 Inc. VAT
ORDER NOW
