**Today Only 25/09/2012** Xigmatek Pantheon Mid Tower Case & Corsair XMS3 8GB 1600MHz Dual Channel K
22 Aug 2010
Xigmatek Pantheon Mid Tower Case - Black @ £33.60 inc VAT
Pantheon – Rome’s temple of gods. Big and impressive by a great architecture and dedicated engineering for all your hardware, Xigmatek proudly presents our latest exclusive chassis – the Pantheon. Decent design combined with features such as our tool free design for the 5.25” bays, 6 hot swap hdd cages including anti vibration, black interior and exterior, usb 3.0, 2 fan controllers, last but not least also the radiator support of 240/280mm radiator on the top. Get yourself a piece of ancient experience and flair and start the combat with Pantheon!
Two 2.5”/3.5” front-opened hot-swappable HDD trays; USB3.0 super-speed port and two fan speed control knobs on the top panel; Both side screw-less ODD holders with anti-vibration rubbers; Thumb screws for add-on card easy installation; 1 Year Warranty
- Dimension: 206(W) x 543(H) x 500(D) mm (8.1*21.4*19.7 inches);
- Drive Bay: External x 4 with both side tool-free holders with anti-vibration rubbers;
- Expansion Slot: 7 slots, 330mm free length for long card.(Thumb screws);
- Motherboard Support: ATX, Micro ATX (with cooler blackplate easy installation window);
- Power Supply: Standard P/S2 ATX/EPS power supply unit; 1. Intake airflow hole with dust filter; 2. - Available for face upward and downward installation; 3. Within anti-vibration rubber;
- Cooling System: Air-cooling; Front Fan: Pre-installed 120mm white LED with black blades x 2 on HDD cage and LED is on/off switchable.(Max. four 120mm fans on HDD cage both side.); Rear Fan: Pre-installed 140mm white LED with black blades x 1 and LED is on/off switchable.(120mm fan is available); Side Fan: Pantheon-Original: Optional 120/140mm fan x 2 Bottom Fan: Optional 120/140mm fan x 1 (with dust filter); Top Fan: Optional 120/140mm fan x 2 or 170mm fan*1; Fan Speed Control: Six fan speeds are adjustable synchronously by two knobs on top panel; Water-cooling; Water pipe holes x 4 (with rubber cover) Available for 240/280mm radiator on the top; Radiator size limitation inside of top panel : (L)290*(W)130*(H)42mm;
- I/O Panel Top Panel: Power switch, Reset switch, USB3.0*1, USB2.0 x 2, e-SATA x 1, Audio in/out x 1 (HD Audio), two knobs of fan controller
Only £33.60 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £23.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge/Ivybridge compatible
Only £23.99 inc VAT.
ORDER NOW
