**TODAY ONLY! 25/10/2013** Seagate storage & Raijintek cooling
OcUK Staff
4 Feb 2013
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD @ £44.99 inc VAT
The new Barracuda ST1000DM003 hard drive from Seagate offers customers a compelling new storage choice for high-capacity, high-performance computing solutions. The new Barracuda ST1000DM003 drive is built on a full-speed, 7200RPM platform. Further turbocharged with a huge 64MB cache and the industry’s new, high-performance SATA 6Gb/s interface, the Barracuda ST1000DM003 drive is destined to set a new standard for high-speed desktop performance. Discerning high-performance PC users, multimedia development professionals and power users in general will appreciate the capacity, performance and flexibility the Barracuda ST1000DM003 drive offers.
- Backwards compatible with SATA-II
- Capacity: 1TB
- Cache: 64MB
- Interface: SATA 6Gb/s
- Spin Speed: 7200RPM
- Warranty: 1 Years
Only £44.99 inc VAT.
ORDER NOW
__
Raijintek EreBoss High Performance CPU Cooler @ £29.40 inc VAT
EreBoss, is a giant heat-sink with world’s top slim type 14013 fan, is an extremely good value cooler. “Designed in Germany”, Ereboss is manufactured to provide users an awesome performance but at a great price point. The Ereboss fan is a slimline 140mm fan at 13mm thickness, but provides outstanding performance.
Key Features
- Nickel copper base, efficient 6mm Heat-pipe*6 & ultra large dissipating area fin
- Super Slim type 14013 PWM fan - 13mm height; Low noise & outstanding air flow as well pressure
- Multiple mounting kits for a wide range of sockets
- Patent designed holes on fins to provide excellent air flow and cooling efficiency
- Dual fans installation option and anti-vibration rubber attached.
Specification
• Dimension: 140(W) x 110.5(D) x 160(H) mm
• Base Material: Nickel Copper
• Fin Material: Aluminum Alloy; Solder-free fins assembly
• Heat-pipe:6pcs.
• Fan Dimension: 140(W) x 150(H) x 13(D) mm
• Voltage Rating 12V
• Starting Voltage 7V
• Speed: 1100 ~ 1650 R.P.M.
• Bearing Type: Sleeve Bearing
• Air Flow: 66.65 CFM (Max.)
• Air Pressure: 1.72 mmH2O (Max.)
• Life Expectance: 40,000 hrs
• Noise Level: 28 dBA
• Connector: 4 pin with PWM
• Weight: 808g (Heat Sink
Only £29.40 inc VAT.
ORDER NOW
Boring - expected more from Fridays deal! ;)
Gibbo dropped the price on the Asus 7990 pre-order that was on special yesterday, believe it's still on special!
Asus HD 7990 6144MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
With more than twice the processing power of previous generation AMD discrete graphics cards, ATI Radeon HD 7900 Series graphics cards deliver a cinematic gaming experience and unprecedented performance.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- HD 7990 is a dual GPU card
- Core Clock Speed: 950MHz
- Core Boost Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 64 CU / 4096 ALU
- Texture Units: 256
- ROPS / Z-Stencil: 64 / 256
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 2x384 bit / 6000MHz
- Load / Idle Board Power: <500W / <3W
- Power Connectors: 2x 8-pin required
- Display Outputs: DL-DVI-I, 4x Mini-Displayport
- AMD Golden Ticket: Choose 3 FREE Games: http://www.amd4u.com/radeonrewards/
- 3yr Warranty
Was [£599.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
