**TODAY ONLY! 26/06/2014** Save £90 on a system, and £30 on a graphics card, look inside!
OcUK Staff
12 Apr 2008
OcUK HQ
"Titan Tanto" Intel Core i5 4670K @ 4.2GHz Overclocked Nvidia GeForce Gaming PC @ £779.95 inc VAT
Introducing the "Titan Tanto" Nvidia GeForce Gaming PC based on the very latest cutting edge Intel Haswell architecture. Equipped with an Intel Core i5 4670K overclocked to a impressive 4.2GHz, powerful quad core performance combined with the mighty all new Intel Z87 chipset. You can choose up to a massive 16GB of DDR3 RAM runing at an incredible 2133MHz, delivering blindingly quick multitasking performance. Equipped with a formidable overclock and paired with speedy memory, the "Titan Tanto" has razor sharp performance capable of slicing through the toughest games and demanding applications..
Speed is key. A fast system gets the job done quicker, a fast system games harder. The "Titan Tanto" is equipped a fantastic Nvidia GTX 7 Series graphics card, delivering breathtaking DX11 cinematic graphics. With up to a gigantic 4096MB of VRAM allows for massively graphically intense environments to be loaded smoothy, games such as Crysis 3 and Battlefield 4 take full advantage of this hardware acceleration.
The "Titan Tanto" is contained within the stylish, eye catching NZXT Phantom 530 case finished in a choice of colours. Offering ample space and optimal airflow to keep the "Titan Tanto" running cool and quiet. With dynamic and extrovert styling, you will have a truly unique system, be it at a LAN or at home.
Key Features of this PC
- Quad Core processing & up to 16GB of 2133MHz DDR3 memory
- Midi Tower for easily upgradeability
- Powerful Nvidia GeForce Graphics and Software
- Flexible Specification
System Specification
- Case: NZXT Phantom 530 Gaming Case - Red
- Power Supply: Super Flower 550W Gold PSU
- CPU: Up to Intel Core i7 4770K Quad Core Haswell Processor overclocked to 4.2GHz
- Motherboard: Gigabyte Z87X-SLI (Socket 1150) DDR3 ATX Motherboard
- Cooler: Prolimatech CPU Cooler
- RAM: up to 16GB (2x4GB) DDR3 2133MHz Dual Channel Kit
- Hard Drive: Primary and Secondary SSD & HDD Options Available
- Graphics Card: Nvidia GeForce GTX Graphics Card
- Sound: High Definition 7.1 Onboard Sound Card
Service Package
- Full 24 Month collect and return warranty (Mainland UK and Ireland Only - Return to Base warranty for customers outside of the UK) - Each specification is assembled from handpicked components for compatibility and stability - Telephone, web note and forum technical support
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
Free games provided in conjunction with any components are only provided with this PC if specifically stated in the description above.
Only £779.95 inc VAT.
ORDER NOW
KFA2 GeForce GTX 780 HOF 6144MB GDDR5 PCI-Express Graphics Card **ALL WHITE** @ £399.95 inc VAT
Exclusive to Overclockers UK we have the worlds fastest air-cooled GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
- Gigantic 6GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 1019 MHz
- Core Boost Clock: 1071 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £399.95 inc VAT.
ORDER NOW
Is the 6gb cards worth getting now, lets say you're running 5760x1080 res?
You will need at least 2 cards to run 5780x1080 with nice details/fps and 6Gb will help in some new games.
3gb cards are good at that rez. Only 4k needs 6gb.
Not really,
Watch dogs without AA can use 4.5Gb of vram and more than 6gb with AA. (but yes Watch dogs is broken :p)
Wolfenstein the new order can use more than 3Gb as well.
I play at 5884x1080 (because of bezel compensation) and I'm using 2 Titans
