Seasonic X-Series 1250w '80 Plus Gold' Modular Power Supply @ £149.99 inc VAT
nonl2br
<h1>Features</h1>
- 80 Plus Gold Certification
<br>- DC to DC Converter Design, provides superior dynamic response, greater stability and maximize 12VDC rail output.
<br>- Seasonic patent pending modular cable back panel, with integrated VRM, reduces internal wiring and increases efficiency & quality.
<br>- Super high efficiency for energy savings.
<br>- Dual sided PCB layout for quality & performance
<br>- High current gold plated terminals, reduces current transmission resistance for increased efficiency.
<br>- Conductive solid polymer aluminum electrolytic capacitors
<br>- Advanced ultra-low resistance, high temperature (105°C) electrolytic capacitors
<br>- Improved load voltage regulation keeps the voltage fluctuations on the 12 V output within 0 % to 2 % with no negative tolerance.
<br>- Multi-GPU technologies supported with 6P and 8P PCI-E connectors
<br>- Active Power Factor Correction [99% PF] for reduced line noise and power distortion.
<br>- Universal AC Input for plug and run anywhere around the world.
<br>- >100,000 hours MTBF
<br>- Dual Copper Bars conduct current more efficiently to reduce impedance and minimize voltage drop.
<br>- Smart and Silent Fan Control [S3FC], Seasonic patent pending, with fan control selector switch to S2FC
<br>- Hysteresis Fan Control optimizes how frequently the fan switches on and off during Fanless and Silent modes.
<br>- Sanyo Denki San Ace 12cm double ball, ball bearing fan best noise and cooling performance available.
<br>- Ultra ventilation [Honey Comb Structure] for increased airflow and reduced noise levels.
<br>- Full-Modular cable connections
<br>- Easy Swap peripheral connectors for easy plug and unplug connection.
<br>- Scratch resistant powder coat paint (black)
<br>- Over Power / Over Voltage / Under Voltage / Over Current / Over Temperature/ Short Circuit Protection.
<br>- Energy Star, RoHS, WEEE, ErP Lot 6 & REACH compliant
<br>- cTUVus, TUV, CB, BSMI
<br>- PFC Harmonics compliant, EN61000-3-2: 2000
<br>- CE, FCC, C-tick
<h1>Connectors</h1>
- Motherboard 24 Pin x 1
- CPU 8/4 Pin x 1
- CPU 8 Pin x 1
- PCI-E 8-6 Pin x 10
- Molex 4 Pin x 5
- SATA x 14
- Floppy x 1
- 5 Years Warranty
Only £149.99 inc VAT.
ORDER NOW
_______
Xigmatek Assassin 2 Midi-Tower - White @ £19.99 inc VAT
The Assassin Lurks in the dark, waiting for a chance to strike. Enemy's that come up against the Assassin have no chance to retaliate, no chance to survive. Xigmatek introduces the newest gaming chassis: The Assassin mid-sized tower, Inspired by the latest in advanced gaming concepts and high quality production procedures.
Features
- Includes pre-installed high performance silent Xigmatek fan with FCB (Fluid Circulative Bearing)
- Capable of mounting ATX, Micro-ATX and Mini-ITX Motherboards.
- Detachable dust filters greatly improves quality of air sucked into the chassis.
- Innovative 5 X 3.5” HDD can be converted to 2.5” SSD for easy mix and match.
- Front and top panel – Anti Fingerprint coating minimizes fingerprints on case.
- Supports 170mm tall Side-blow tower coolers.
- Can mount up to 270mm Gaming Graphic cards.
- Fan control.
Specification
- Dimensions: 216 x 513 x 500 mm (W x H x D)
- Material: Steel (body)
- Weight: 8 kg
- Color: White and black
- Form Factor: ATX, Micro-ATX, Mini-ITX
- Filter: Yes
- Power Supply: Standard ATX 1x (optional)
- Maximum video card length: 270 mm
- Expansion Slots: 7
- Total fan possible: - 2x 120mm (front), - 1x 120 mm (rear) Included, - 2x 120 mm (cover), - 2x 140/120 mm (Side)
- Drive Bays: - 4 x 5.25 inches (external; tools), - 5x 5x 3.5 inch or 2.5 inch (internal)
- I / O Panel: - 2x USB 3.0 (internal connection), - 1x each Audio In / Out
Only £19.99 inc VAT.
ORDER NOW
nonl2br
<h1>Features</h1>
<h1>Connectors</h1>
- CPU 8/4 Pin x 1
- CPU 8 Pin x 1
- Molex 4 Pin x 5
- SATA x 14
- Floppy x 1
- 5 Years Warranty
ORDER NOW
_______
Features
- Fan control.
Specification
- Weight: 8 kg
- Filter: Yes
ORDER NOW
