Today Only Dealios!
Xigmatek Asgard II Windowed Midi Tower Case - Black/Silver @ £27.98 inc VAT
"Asgard-II"-The Property of Æsir and castle of Odin. As the country of Gods, the inviolable Asgard-II is the world’s first black coating entry-level chassis. Furthermore this chassis is supplied with 1 x 120mm preinstalled black fan, and 3 more fans can be mounted in different areas for best possible airflow. 4 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5” HDDs are available so you can feel free to "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for pc beginners
- Dimensions: 185(W) x 475(D) x 408(H) mm, 0.6mm thickness SGCC.
- Drive Bays: 5.25” External x 4 (Tool-free)
- 3.5” External x 1 (Tool-free)
- 3.5” Internal x 5 (Tool-free)
- Expansion Slots: 7 slots (tool-free), 290mm free add-on card length.
- Motherboard Support: ATX (12” x 9.6”), Micro ATX (9.6” x 9.6”)
- Power Supply: Standard P/2(ATX) or EPS
- Front Cooling: 80/90/120mm x 1 fan is available.
- Rear Cooling: : Preinstalled 120mm black fan x 1 (80/90mm fan is available)
- Side Cooling: 80/90/120mm x 2 fans are available.
- I/O Panel: Front Panel: USB2.0 x 2, HD Audio in/out x 1
Only £27.98 inc VAT.
ORDER NOW
VTX3D HD 7950 X-Edition 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £239.99 inc VAT
VTX3D HD7950 X Edition incorporates the latest PCI-E Gen 3 to get the maximum performance from your GPU. Both fitted with 3GB of GDDR5 memory connected via a new high speed 384 bit memory interface. VTX3D HD7950 X Edition is clocked at 880MHz, also together with 5000Mhz for memory, fulfilling those who thirst for extreme performance. The HD7970 X Edition also features ultra cooling design. With two 92mm ultra big fan and SSU-shape heat pipe design, this efficient cooling solution maximizes the speed of heat dissipation, but minimizes the noisy level, creating most pleasing environment for gaming.
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 880MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
Only £239.99 inc VAT.
ORDER NOW
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
