Corsair Vengeance K70 Mechanical Gaming Keyboard - Black – Brown Switch (CH-9000067-UK) @ £99.95 inc VAT
The Corsair K70 is a fully mechanical, backlit keyboard that’s designed for performance gaming. The built-in Cherry MX Brown switches deliver smooth, linear response for ultra fast double and triple taps without the audible click. Every key is individually lit for brilliant backlighting and easy customizability to highlight important functions. The black anodized brushed aluminum structure provides rugged durability and a professional-grade finish. Replaceable contouBrown keycaps make it easier to find critical WASD keys—even in dim light. Plus the 20 Key Roll-over and 100% Anti-Ghosting mean that every key you touch translates directly into the game.
- Cherry MX Brown Mechanical Switches - Smooth, linear key response for ultra fast double and triple taps without the audible click
- Key-by-Key Customizable Backlighting - Deep Red LEDs with adjustable brightness and per key programmability to light up just the keys you need. Save the keys for your favorite game directly to the keyboard.
- ContouBrown, TextuBrown WASD Keycaps - Keep your eyes on the action with easy to locate FPS keys
- Anodized Black Brushed Aluminum Chassis - Professional-Grade look and feel plus the rugged durability needed for hours of gaming
- Full Key Matrix Anti-Ghosting with 20-Key Rollover - Every keystroke translates into accurate gameplay¡Xeven when multiple keys are pressed.
- Detachable full length wrist rest - Soft touch design that¡¦s comfortable for hours of play and comes off if it gets in your way.
- Cherry MX Brown mechanical switches / 45g Actuation Force / 2mm to actuation and 4mm to bottom / Rated to 50 million operations / Gold contacts
- Replaceable contouBrown, textuBrown WASD Keycaps / Additional keys for WASD and 1-6 number keys
- Up to 1000 Hz USB report rate
- Selectable 8ms, 4ms, 2ms, 1ms and BIOS mode
- Deep Brown LED backlighting with key-by-key programmability to light up individual keys / 650nm Brown LEDs
- Aluminum unibody construction for increased strength, durability and rigidity
- Six dedicated multimedia keys / STOP, PREVIOUS, PLAY/PAUSE, NEXT, MUTE, VOLUME UP/DOWN roller
- Windows Lock key for uninterrupted game play
- Product Dimensions: 438 x 166mm
- Product Weight: 1200g
Only £99.95 inc VAT.
ORDER NOW
______
Asus Xonar D2X 7.1 PCI-E Sound Card @ £69.95 inc VAT
With the introduction of Windows Vista, the whole audio architecture landscaped has been changed. This has resulted in teething problems for gamers - with the possibility of losing all surround sound or hardware accelerated Direct3D and EAX while gaming in the Windows Vista environment. To circumvent this problem, the Asus Xonar family of audio cards utilizes an Asus exclusive technology - the new DS3D GX extension in the Xonar D2X driver; to provide full support for surround sound and hardware accelerated features by translating DirectX to the DS3D GX. While other solutions like OpenAL requires special installation and game support, DS3D GX doesn't. Gamers can enjoy DirectX gaming with hardware enhanced surround sound and EAX effects automatically and immediately after installation. Asus Xonar D2X audio card, dedicated to be the best audio card for gaming and home entertainment, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24-bit ultra fidelity input and output with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2X is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Centre, which you will never have with onboard audio or other sound cards.
- PCI-Express Interface
- Vista Gaming with DirectSound & EAX support
- Hi-Fi class audio quality with SNR up to 118dB
- Dolby HomeTheater Technologies & DTS Connect
- Valuable Cakewalk and Ableton Live music production software bundled
- Unprecedented SSNR NR Up to 118db reaching the limit of PC audio sound quality clarity
- Full duplex High-definition audio processing at 192KHz/24Bit for all Input and outputs and Inputs
- Versatile Dolby/DTS Audio Technologies for Game, Music, and Video
- Accurate 3D sound positioning and hardware acceleration for PC gaming
- Real-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System
- Requires floppy power-connector
- Vista Ready
Only £69.95 inc VAT.
ORDER NOW
ORDER NOW
______
- Vista Ready
ORDER NOW
