Today Only deals! Catch them before deal stock runs out!
Silverstone Fortress FT03 Mini Case - Black (SST-FT03B-Mini USB 3.0) @ £99.98 inc VAT
After releasing the ground breaking Fortress FT03 chassis in 2011, SilverStone engineers took on the challenge of making a smaller version to further increase the appeal of this unique computer form factor. Through intelligent planning and reengineering, the engineers were able to create the FT03-MINI, which improves on the simplistic design of the FT03 while reducing the size by 50%. Using 2.5mm thick, sand-blasted and anodized aluminum outer shells with no cable connectors and vents on all four sides to complement an efficient, organized layout, this chassis helps SilverStone to again set new standards in small form factor computers.
The interior of the FT03-MINI utilizes SilverStone’s unique stack effect cooling layout so a Mini-ITX motherboard is mounted in 90 degree rotation to take advantage of hot air’s natural tendency to rise. The FT03-MINI can accommodate graphic cards up to 10”, support one 3.5” and two 2.5” drives, and even entry-level liquid cooling can be installed to satisfy needs of enthusiasts. As the new small form factor chassis addition to the Fortress series, the FT03-MINI is truly a paradigm.
- Super mini footprint design with no cables and vents on four sides
- Ample space for CPU cooling (78mm in height)
- Elevated standoff for motherboard back side components
- Includes 140mm Air Penetrator fan and support entry level liquid cooling
- Support for two 2.5” SSD/hard drives and one 3.5” hard drive
- Mini-DTX / Mini-ITX motherboard & SFX PSU compatible
- Standard-length expansion cards support (10 inches)
- Material: Aluminum outer shell, steel body
- Motherboard: DTX, Mini-ITX
- Drive Bay: External 12.7mm Slot loading slim optical drive x 1
- Internal: 3.5” x 1 , 2.5”x2
- Bottom: 1 x 140mm Air Penetrator fan, 1500rpm
- Expansion Slot: 2
- Front I/O Port: USB 3.0 x 2 / Audio x 1 / MIC x 1
- Power Supply: 1 x Optional standard SFX
- Expansion Card: Compatible up to 10” long
- Limitation of CPU cooler: 78mm
- Limitation of PSU: SFX PSU
Only £99.98 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £23.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £23.99 inc VAT.
ORDER NOW
- Expansion Slot: 2
ORDER NOW
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Type: 240-pin DIMM
Black PCB
Warranty: Lifetime
ORDER NOW
