**Today Only 27/01/2012** Less than £90 - Samsung SpinPoint F4 EcoGreen 2TB & Save £20 on Asus VE247
22 Aug 2010
Hi Guys,
two great savings today. Hard drive pricing is slowly creeping it's way down you will be glad to hear and now you can pick up a 2TB for less than £90!
You can also get a A truly incredible price for this stunning 2ms LED monitor with DVI & HDMI inputs with the Asus VE247H 24" Widescreen LED Multimedia Monitor
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black @ £149.99 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 23.6"(59.9cm) 16:9 Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.272mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI 1.3,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 35 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 569.4 x409.7x201mm
- Box Dimension(WxHxD): 638x 480 x175mm
- Weight Net Weight (Esti.): 4.4 kg
- Gross Weight (Esti.): 7.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
Only £149.99 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £89.99 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
Only £89.99 inc VAT.
ORDER NOW
A 2TB drive under £90 in the current climate, and a 24" LED monitor from a good manufacturer for under £150? Genuinely impressed guys, nice ones. :)
Very nice deal on the HDD, might hold out a while longer before getting the storage I was originally planning for my build before the price hikes :P
