**TODAY ONLY! 27/07/2015** Seasonic G series 650w 80+ Gold Modular PSU & Western Digital Caviar Gree
OcUK Staff
4 Feb 2013
Seasonic G series 650w '80 Plus Gold' Modular Power Supply
Features
- DC to DC Converter Design, provides superior dynamic response, greater stability and maximize 12VDC rail output.
- Seasonic patent pending modular cable back panel, with integrated VRM, reduces internal wiring and increases efficiency & quality.
- Super high efficiency for energy savings.
- Dual sided PCB layout for quality & performance
- High current gold plated terminals, reduces current transmission resistance for increased efficiency.
- Conductive solid polymer aluminum electrolytic capacitors
- Advanced ultra-low resistance, high temperature (105°C) Grade A capacitors
- Enhanced tight regulation +12V outputs (±3%) to broaden utilization capabilities.
- Supports PCI-E video card technologies.
- Active Power Factor Correction [99% PF] for reduced line noise and power distortion.
- Universal AC Input for plug and run anywhere around the world.
- >100,000 hours MTBF
- Smart and Silent Fan Control [S2FC], Seasonic patent pending
- Honghua 12cm FDB fan for increased airflow, lifetime and reduced noise levels.
- Ultra ventilation [Honey Comb Structure] for increased airflow and reduced noise levels.
- Standard cable connections
- Easy Swap peripheral connectors for easy plug and unplug connection.
- Scratch resistant powder coat paint (black)
- Over Power / Over Voltage / Under Voltage / Over Current / Over Temperature/ Short Circuit Protection.
- Energy Star, RoHS, WEEE, EuP Lot 6 & REACH compliant
- cTUVus, TUV, CB, BSMI, GOST-R
- PFC Harmonics compliant, EN61000-3-2: 2000
- CE, FCC, C-tick
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 1 x 8-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 5 x 4-Pin-Molex
- 1 x FDD
- Warranty: 5yr
£79.99 inc VAT
BUY NOW!
_____
Western Digital Caviar Green 6TB SATA 6Gb/s 64MB Cache - OEM
The advantage of cool & quiet
Heat has a large impact on the overall reliability of a HDD’s life over time. It can also lead to increased power consumption, the requirement of additional fans and increased fan operation, increased noise levels and the increased chance of failure. WD Green drives come equipped with WD GreenPower Technology which allows the drive to operate cooler with increased overall reliability.
Power management with performance
Best-in-class power management, reduced heat output, and next-generation technologies such as IntelliSeek offer a perfect balance of performance and power, making WD Green a leader in performance when compared to the competition with our 6 TB HDD.
Reliability with an increased lifespan
Quiet acoustics, reduced vibration and advanced 4K HDD formatting makes WD Green a stronger solution when compared to the competition and perfect for PCs and external drive applications. WD Green also features a Dual Stage Actuator, which delivers higher precision motion for 2X the data performance and increases drive reliability.
Capacity storage
Large capacity offerings of up to 6 TBs help expand customer capabilities and application usage of WD Green including primary installations in desktop PCs, as secondary storage in external cases or as reliable backup storage.
Next-generation technology
Reduced power consumption, improved data tracking, and WD GreenPower Technology all help to improve the overall reliability of WD Green making it an efficient solution that lowers your total cost of ownership. NoTouch Ramp Load Technology also protects the drive by ensuring the recording head never touches the disk media, reducing wear and tear to the head and increases drive reliability.
Easy upgrade
Acronis True Image, available as a download on the WD Support website, enables you to clone or copy all your data to a new drive so you don't have to reinstall your operating system and applications to get all the benefits of a new drive.
The WD advantage
WD puts our products through extensive Functional Integrity Testing (F.I.T.) prior to any product launch. This testing ensures our products consistently meet the highest quality and reliability standards of the WD brand. WD also has a detailed Knowledge Base with more than 1,000 helpful articles as well as helpful software and utilities. Our customer support lines have longer operational hours to ensure you get the help you need when you need it. Our toll-free customer support lines are here to help or you can access our WD Support site for additional details.
Recommended use
WD Green storage is tested and recommended for primary use in desktop and All-in-One PCs, as secondary storage for archiving, in external cases or as reliable backup storage.
£169.99 inc VAT
BUY NOW!
I wonder how much HDD space you are going to loose when you format that 6tb HDD? :/ Really want one though.
Plenty left over :) Usable capacity will be 5.45 TB.
Wouldn't use the Green's as a working drive for installing programs/games because there are better alternatives, I use mine for image backups and temporary storage.
I am after a large capacity drive for my games drive. My 3tb is nearly full so want something larger, around 6tb.
Up to you HaloUK... for a gaming drive I would opt instead for the very capable 4TB WD Caviar Black and is a few quid cheaper with better access times and fast dual processor. Add a second if you need to install more than 250 games as libraries can be split across drives.
Only downside to Caviar Blacks is the noise being noticeable when loading larger levels or higher quality assets but not annoyingly so. Same audio levels you get from most 2TB HDDs.
Emphasis being on good all round performance at higher capacities, my other alternative would be the 6TB Seagate enterprise version but that is double the cost and prohibitive for most that manage drives that fits the purpose as I outlined originally.
