**Today Only 27/09/2011** Asus GeForce GTX 560Ti DirectCU II TOP & Kingston HyperX Genesis Grey 8GB
22 Aug 2010
Today only special offers! Selected products, dropped prices - Happy Customer! :D
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £174.98 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
- Supplied FREE with Batman: Arkham City FULL PC game (subject to availability. Game is launched on 21/10/2011 downloads previous to this date will be declined) (Only supplied with orders purchased after 07/09/2011)
Only £174.98 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £39.98 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £39.98 inc VAT.
ORDER NOW
V Nice price on the ram, shame about the voltage tho, woudl've been ideal for a SB build ater in the year considering RAM prices are probs gonna rise a bit by then.
Valkia, can I ask a favour of you?
Can you measure the length of the Asus card for me and let me know how long it is? Just that it'd be for a Sugo SG06 with a rad in the front and I have a strict 236mm length to work with.
Also, are the power connectors on the top or back of the card?
Thanks.
Purchased RAM with free delivery!
Have 4GB (2X2GB) of same RAM so this is probably a pointless purchase, but I guess I sell the 4GB on ebay! ;)
I assume you cannot mix the two together to make 12GB... is that right??
Thguhty itw as recommended to use 1.35v on SB?
Or am I inventing numbers? :confused:
Nope thats CPU.
Infact in our own testing we found 1.65v RAM was also fine, the early issues with Sandybridge was more down to CPU voltage, but 1.65v is OK, though we recommend a safe maximum of 1.60v and wherever possible run lower as less voltage is less heat and less heat results in longer lifespan.
You could, if you have the slots, but it's usually better to run matched kits if possible.
Worth a try as I doubt you'd get much for the RAM on Ebay with the prices dropping so low lately, you can always sell it later if it doesn't work well with the Kingston kit.
Bought the same kit last time it was on offer.
Tempting to buy another lot while it's cheap!
Wanting a 4GB kit to go on offer though *hint hint* for when I build a HTPC for the rents. ;)
Nice deals, oh well, I bought this last week ... EVGA GeForce GTX 560Ti DS SuperClocked 1024MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** ... didn't get the free game though.
Rob you will get the free game, it will come later via email. although where i got my 560ti from I emailed the contact that was on the promotion page, got my code ready for the download.
