Today Only Deals!!!
Xigmatek Asgard II Windowed Midi Tower Case - Black/Orange @ £29.99 inc VAT
"Asgard-II"-The Property of Æsir and castle of Odin. As the country of Gods, the inviolable Asgard-II is the world’s first black coating entry-level chassis. Furthermore this chassis is supplied with 1 x 120mm preinstalled black fan, and 3 more fans can be mounted in different areas for best possible airflow. 4 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5” HDDs are available so you can feel free to "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for pc beginners
- Dimensions: 185(W) x 475(D) x 408(H) mm, 0.6mm thickness SGCC.
- Drive Bays: 5.25” External x 4 (Tool-free)
- 3.5” External x 1 (Tool-free)
- 3.5” Internal x 5 (Tool-free)
- Expansion Slots: 7 slots (tool-free), 290mm free add-on card length.
- Motherboard Support: ATX (12” x 9.6”), Micro ATX (9.6” x 9.6”)
- Power Supply: Standard P/2(ATX) or EPS
- Front Cooling: 80/90/120mm x 1 fan is available.
- Rear Cooling: : Preinstalled 120mm black fan x 1 (80/90mm fan is available)
- Side Cooling: 80/90/120mm x 2 fans are available.
- I/O Panel: Front Panel: USB2.0 x 2, HD Audio in/out x 1
Only £29.99 inc VAT.
ORDER NOW
Zalman CNPS9900-MAX Blue LED CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM3) @ £31.19 inc VAT
Optimally designed pure copper fins effectively disperse heat away from the CPU via composite heatpipes, while the high capacity 135mm fan quickly cools the heatsink for stable operation of high performance CPUs. CNPS9900 MAX utilizes Composite heatpipe which is 50% more effective in transferring heat compared to ordinary heatpipes. An ultra quiet 135mm fan is incorporated for minimized noise. The entire copper heatsink of CNPS9900 MAX is ‘Black-Pearl’ Nickel Plated for long-term corrosion resistance, while the deep ‘Black-Pearl’ tone along with the high intensity Blue / Red LEDs reinforce its powerful aesthetics.
- Dimensions: 94(L) x 131(W) x 152(H)mm
- Weight: 755g
- Materials: Pure Copper/Black-Pearl Nickel Plated
- Dissipation Area: 5.4cm
- PWM Fan Controlller
- Fan Bearing: Long life bearing
- Fan RPM: 900 - 1900
- Fan Noise: 18 - 30dBA
- 300w Cooling Performance
- Includes ZM-STG2 Thermal Grease
Only £31.19 inc VAT.
ORDER NOW
ORDER NOW
- Weight: 755g
ORDER NOW
