**Today Only 27/12/2010 Antec 300 gaming case & Samsung SpinPoint F4 2TB
22 Aug 2010
Today Only, we have 20 amount of units of Antec 300 Three Hundred Ultimate Gaming Case for only £46.99 inc. VAT. The Antec 300 is impressively spacious and unbeatably reliable. Featuring a cable management compartment which keeps your system organized.
We also have 50 units of Samsung SpinPoint F4 2TB for just £58.74 inc. VAT. With enough space for all your important files, movies & pictures this drive is a perfect backup drive.
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £46.99 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for all the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Only £46.99 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £58.74 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Only £58.74 inc VAT.
ORDER NOW
Was just about to order 2 1.5tb from a competitor, free shipping on the sammy drive got me though ordered from ocuk ta ;)
PS thanks to gibbo for sorting me out on my gfx card, much appreciated andy.
Fancy doing the hard drives again once the banks are open so I can put my Christmas money in and then buy? :)
