**TODAY ONLY! 27/12/2013** MSI R9 290 "BF4 Edition" & Hazro HZ29WiA 8-Bit 29" LED SuperWide
OcUK Staff
4 Feb 2013
MSI Radeon R9 290 "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £319.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification
Radeon R9 290
- GPU: Hawaii Pro
- Stream Processors: 2560
- Core Speed: 947MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Features
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £319.99 inc VAT.
ORDER NOW
_____
Hazro HZ29WiA 8-Bit 29" LED Super-Widescreen Professional Monitor - Black @ £299.99 inc VAT
Hazro HZ29WiA greatly enhances your productivity and experience; work and leisure won’t be the same with features like the ultrawide cinematic screen, screen-splitter function, and dual link-up. Whether it’s for viewing multiple documents, a more immersive movie and gaming experience, or multitasking simplicity, the 29” Ultrawide 21:9 screen monitor gives you what you need.
Specification:-
- Panel Technology: AH In Plane Switching - 3H Anti Glare Hard Coating
- Size: 29“ / 73 cm (UW-UXGA)
- Aspect Ratio: 21:9
- Viewable Image: 672.77 x 283.82 mm
- Pixel Pitch: 0.0876(H) mm x RGB x 0.2628
- Luminance (typ.): 300 cd/m²
- Contrast (typ.): 1000:1 / 2000000:1 (dynamic)
- Viewing Angle: 178° horizontal / 178° vertical
- Response Time (typ.): 8 ms (grey-to-grey)
- Colors / Gamut: 16.7 million (8bit) / 100% sRGB (82% CIE1976)
- Connectivity: 1 x DVI-D, 1 x DisplayPort (10 bit), 1 x HDMI, 1 x RGB (VGA)
- Power: DC 4pin 120W (24V)
- Horizontal Frequency: 31.5 - 98.7 kHz
- Frame Rate: 30 - 85 Hz
- Optimal Resolution: 2560 x 1080 Pixels @ 60 Hz
- Mounting Options: VESA 100x100 (M4 Thread) / Base removable
- Warranty: 2 Years Swap Out
Only £299.99 inc VAT.
ORDER NOW
I was sure he said, "Wait for tomorrow" while also inferring that the £100 was coming off..
Aw well, I suppose it would be an extremely silly price if he had..
