BitFenix Colossus M Mini ITX - Black @ £47.99 inc VAT
The spacious interior offers two preinstalled 120mm front and rear fans, and includes the option to install up to five 120mm fans for extra cooling boost. Up to five 3.5" drives or seven 2.5" drives in total can be installed, or for those looking to run high-end graphics cards up to 330mm, the 3 bay FlexCage™ can be easily removed. Colossus Mini-ITX supports installation of thick 240 mm radiators on the top or front, and the easily removable bottom dust filter prevents from dust accumulating dust inside the case over time. Colossus Mini-ITX is the perfect choice for enthusiasts who are looking for compact stylish case with excellent water cooling support and massive storage options.
Features:-
- Futuristic Form – Bold lines with a compact design
- LiteTrak™ Technology – Smooth multimode lighting with three colours and an included pulse mode
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- Maximum Storage Potential – Five 3.5" HDDs or eight 2.5" SSD locations available
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Friendly Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
Specification:-
- Materials: Steel, Plastic, SofTouch™
- Colours (Int/Ext): Black/Black
- Dimensions (WxHxD): 250 x 330 x 374mm
- Motherboard Sizes: Mini-ITX
- PCI Slots: x 2
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: LiteTrak™ lighting system, SofTouch™ surface treatment, tool-free drive locking mechanisms, filtered intakes
Drives:-
- 5.25" Drive Bays: x 1
- 3.5" Drive Bays: x 5
- 2.5" Drive Bays: x 8 (5 + 2 + 1 )
Cooling:-
- Top: 120mm x 2 (optional)
- Front: 120mm x 2 (1 included) or 140/180/200/230mm x 1 (optional)
- Rear: 120mm x 1 (included) or 140mm x 1 (optional)
I/O:-
- USB 3.0 x 2, HD Audio
Only £47.99 inc VAT.
ORDER NOW
_____
Hazro HZ30WiG V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black Metal Casing **CLEARANCE** @ £359.99 inc VAT
**CLEARANCE SALE, BRAND NEW WITH 1yr WARRANTY**
The Hazro HZ30WiG is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. AH-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiG performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiG recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiG collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiG, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiG offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiG is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Specification:-
- Panel Technology: AH In Plane Switching - 3H Anti Glare Hard Coating
- Size: 30“ / 75.6 cm (WQXGA)
- Aspect Ratio: 16:10
- Viewable Image: 641.3 mm x 400.8 mm
- Pixel Pitch: 0.251 mm
- Luminance (typ.): 350 cd/m²
- Contrast (typ.): 1000:1 / 2000000:1 (dynamic)
- Viewing Angle: 178° horizontal / 178° vertical
- Response Time (typ.): 6 ms (grey-to-grey)
- Colors / Gamut: 1.074 billion (10 bit per color)
- 107% Adobe RGB, 120% NTSC (CIE 1931) 100% ISOcoated v2 (UDACT), 98% ECI-RGB
- Connectivity: 1 x DVI-D, 1 x DisplayPort (10 bit), 1 x HDMI, 1 x RGB (VGA)
- Power: DC 4pin 120W (24V)
- Horizontal Frequency: 31.5 - 98.7 kHz
- Frame Rate: 30 - 85 Hz
- Optimal Resolution: 2560 x 1600 Pixels @ 60 Hz
- Mounting Options: VESA 100x100 (M4 Thread) / Stand removable
- Warranty: 1 Years Swap Out
- Assembled in: United Kingdom
Only £359.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- PCI Slots: x 2
Drives:-
Cooling:-
I/O:-
ORDER NOW
_____
Specification:-
ORDER NOW
