**Today Only 28/08/2013** KFA2 GeForce GTX 760 2GB & Avexir MPower Yellow Series 8GB
22 Aug 2010
Today Only Deals!!
KFA2 GeForce GTX 760 2048MB GDDR5 PCI-Express Graphics Card with FREE GPU Keyring @ £191.99 inc VAT
The KFA2 GTX 760 is a powerful, feature-rich card stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, ShadowPlay, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.
Specification:-
- Core Clock: 980MHz (GK104)
- Core Boost Clock: 1033MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1152
- Shader Clock: 1960MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
- Review: http://hexus.net/tech/news/graphics/57205-kfa2-launches-trio-geforce-gtx-760-cards/
Only £191.99 inc VAT.
ORDER NOW
Avexir MPower Yellow Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CM) @ £49.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower series is designed to be a perfect visual match for MSI Mpower mainboards and certain models of Asrock mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Yellow high performance heatspreaders
- Yellow LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-9-9-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Only £49.99 inc VAT.
ORDER NOW
Thats a nice deal on some RAM
if my pay goes in today will have to look at getting some, if they are still in stock
