**Today Only 28/09/2012** XFX Pro 850W Core Edition '80 Plus Bronze & Steelseries Kinzu V2 3200 DPI
22 Aug 2010
Today only deals!
Power & Precision
XFX Pro 850W Core Edition '80 Plus Bronze' Power Supply @ £79.98 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
- Fixed SATA: up to 11
Only £79.98 inc VAT.
ORDER NOW
Steelseries Kinzu V2 3200 DPI Rubberised Black Gaming Mouse (62022) @ £15.00 inc VAT
The SteelSeries Kinzu v2 brings together a compact and simplistic style that includes 3 programmable buttons and an optical sensor. Featuring 3,200 CPI and registering 3,600 frames per second, the Kinzu v2 is lightweight with a double braided nylon cord.
- Number of Programmable Buttons: 3
- Scroll Wheel: Yes
- Number of Buttons: 4
- Frames per Second: 3600
- Inches per Second: 65
- Counts per Inch (CPI): 400, 800, 1600, 3200
- Ambidextrous: Yes
- Profiles Available: Yes
- Macros Available: Yes
- Statistics Available: Yes
- Gold Plated Connector: Yes
- Cord Material: Braided
- Number of Illumination Colors: 1
- Number of Illumination Zones: 1
- Sensor Type: Optical
- Multiple Colours: Yes
Only £15.00 inc VAT.
ORDER NOW
