**Today Only 28/12/2010** Samsung SpinPoint F3 1TB £38.29 & Corsair XMS3 4GB Memory £38.76
22 Aug 2010
Today Only, we have 50 units of Samsung SpinPoint F3 1TB Hard Drive for only £38.29 inc. VAT. This huge storage drive has easily enough space for all your important files, photos & films. Make sure you backup your happy memories!
We also have 40 units of Corsair XMS3 4GB 1600MHz DDR3 Memory for just £38.76 inc. VAT. If you are looking for fast and reliable memory, look no further. The Corsair XMS3 is rated at a blazingly fast 1600MHz and with a fantastic latency of 9-9-9-24, this memory will not disappoint.
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £38.76 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Only £38.76 inc VAT.
ORDER NOW
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) @ £38.29 inc VAT
The F3 operates at 7200RPM with offerings of up to 1TB data storage capacity by using two 500GB per platter disks. As well as meeting datacentre requirements for addition storage to meet rising demand and increasing performance needs, the new drives also deliver high-performance with lower power for desktop computers and servers.
- Capacity: 1TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.9ms
- Warranty: 3 Years
Only £38.29 inc VAT.
ORDER NOW
Hi,
What's the difference between this F3 and the the one which is on the weekly deal?
they have the same name, but the daily deal one looks like it might have faster spin speed. Is this correct?
This is the 7200RPM unit where as the one on the weekly deal is the 5xxxrpm unit. This makes the HD103SJ a little quicker.
I've got a bit of a problem with this deal on the XMS3; I need two of them, but it'll only let me have one! And on top of that, my free delivery option seems to have disappeared so if I buy them in two separate orders, I have to pay £8 per order for the delivery!?
I don't mind buying the 2nd 4GB at normal price, but how do I go about it?
Some Today only deals do not have free delivery and only per order, Just added another item to my basket and I got free delivery, mind you it was a £300 gpu!
Does this memory work on am3 systems? Says 'designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions' in the description.
With delivery added the drives work out about the same as they cost before. :/
Sweet price on the memory though.
wow, 38 quid for 4gb 1600mhz memory. Just 6-8 months ago the faily ocz 1333 golds would have set me back £110. Make me wonder what my platinums are currently worth...
