**Today Only 29/04/2013** Acer GD245HQ 23.6" 120Hz 3D Widescreen Monitor & Avexir MPower Red Series
22 Aug 2010
Pimp out your system with the Avexir 2800MHz LED memory kit at a special reduction on today only. We also have a smooth 120Hz Acer 3D monitor at a special price. 120Hz gaming is highly recommended, you can even notice the smoothness on the desktop!
Acer GD245HQ 23.6" 120Hz 3D Widescreen LCD Monitor with 3D Glasses (ET.UG5HE.A07) - Black @ £179.99 inc VAT
The Aspire GD245HQ 3D monitor is engineered for the graphics-intensive, win-or-lose moments of today's leading high-definition 3D games. The radical design, ultra-high performance and immersive 3D visuals take gaming to the next dimension. The brilliant 23.6" widescreen displays true HD quality at a vivid 1920x1080 resolution. Intense, fast-action playback is perfectly smooth with a 120Hz refresh rate and 2ms response time, giving you the ultimate gaming experience. The HDMI and DVI interfaces provide advanced connectivity to the latest graphics cards and digital video sources.
Upgrade your PC to a fully immersive stereoscopic 3D experience with NVIDIA 3D Vision. A combination of high-tech wireless glasses and advanced software, 3D Vision automatically transforms hundreds of PC games into full stereoscopic 3D. Just slip on the stylish glasses and pair them with this monitor to experience characters and environments come to life on the screen. In addition, you can watch 3D movies and 3D digital photographs in eye popping, crystal-clear quality. Give your eyes something to talk about with NVIDIA 3D Vision.
- 3D Vision Glasses included
- Screen Size: 23.6" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 80000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 574.8mm x 417.8mm x 194.4mm
- Weight: 5.8kg
- Warranty: 2 Years
Only £179.99 inc VAT.
ORDER NOW
Avexir MPower Red Series 8GB (2x4GB) DDR3 PC3-22400C12 2800MHz Dual Channel Memory Kit (AVD3U28001204G-2CI) @ £149.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower Red series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Red high performance heatspreaders
- Red LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 12-14-14-35
- Dual Channel Kit: (2x4GB)
- 100% tested at 2800MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £149.99 inc VAT.
ORDER NOW
