Today's Deals!
Samsung SH-224DB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM @ £14.99 inc VAT
The SH-S224 drive offers a powerful over-speed performance feature that enables consumers to burn data at high speeds - even on low speed media. With over-speed recording, users can write at 24X speeds on 16X media and 12X speeds on 8X media. As lower speed media is more cost-effective, users can save money while burning discs at faster speeds.
The SH-S224 drive provides blazing recording speeds across a gamut of different data media types including 24X DVD±R recording, 12X DVD-RAM recording, 16X DVD+R Dual Layer recording, 12X DVD-R Dual Layer recording, 8X DVD+RW recording and 6X DVD-RW recording. It enables consumers to burn 4.7GB on a DVD±R disc in approximately 4 minutes and 26 seconds, a 6 percent increase in speed compared to a 20X DVD writer. It also takes less than 12 minutes to burn 4.7GB in DVD-RAM format, which is a 30 percent increase in speed over a 20X DVD drive.
Samsung's SH-S224 drive supports SATA interface, the dominant interface for PCs.
As with Samsung's complete WriteMaster optical disc drive lineup, the SH-S224 features specific technology that ensures best-of-breed performance including SAT1 (Speed Adjustment Technology), TAC2 (Tilt Actuator Compensation) and Double OPC3 (Optimum Power Control). Buffer Under Run Free Technology4 supports stable writing under high speed, and Magic Speed5 and ABS (Automatic Ball Balancing System) 6 technologies reduce vibration and noise. The SH-S224 is also eco-friendly designed and is RoHS compliant.
Write Speed
- DVD-R: 24x
- DVD-R: 24x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Only £14.99 inc VAT.
ORDER NOW
Avexir Core Blue Series 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16001008G-2CW) - Blue Light @ £89.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black high performance heatspreaders
- Blue LED Strobe lighting effect (See product images)
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-9-9-24
- Dual Channel Kit: (2x8GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Only £89.99 inc VAT.
ORDER NOW
Write Speed
- DVD-R: 24x
- DVD-R: 24x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
ORDER NOW
Features:
- Black PCB
- Lifetime Warranty
ORDER NOW
