**Today Only 29/12/2010** Arctic Cooling Freezer 7 Pro Rev 2 £14.99 & Gigabyte GA-G31M-ES2L Motherbo
22 Aug 2010
Today Only, we have 25 units of Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler for only £14.99 inc. VAT. The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with socket 775, AM2, AM3, 1156 and 1366. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers available for power users.
We also have 20 units of Gigabyte GA-G31M-ES2L Intel G31 DDR2 Motherboard for just £29.99 inc. VAT. Based on the classic Intel G31 chipset, the Gigabyte G31M-ES2L provides HD output out the box.
Gigabyte GA-G31M-ES2L Intel G31 (Socket 775) DDR2 Motherboard @ £29.99 inc VAT
The GA-G31M-ES2L supports Intel's latest high performance CPUs, which deliver the most energy-efficient performance available today. Based on Intel's Micro Architecture, the Intel multi-core processors with 4 cores and two shared L2 caches provide the best capability-per-watt solutions and are an ideal choice for multi-media enthusiasts and intensive multi-tasking environments. This cutting-edge processor offers significant performance boosts and provides an overall more energy efficient platform.
- Revolution energy saving design with Easy Energy Saver technology to FSB 1600 (O.C.)
- Supports Intel Core 2 multi-core and upcoming 45nm processors
- Solid capacitors and Ferrite core choke design in CPU VRM
- Dual Channel DDR2 1066(O.C.) for remarkable system performance
- Integrated Intel Graphics Media Accelerator 3100 (Intel GMA 3100)
- Features high speed Gigabit Ethernet
- Integrated 8 channel High Definition audio
- DualBIOS solution gives a multiple security to the system
Only £29.99 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) @ £14.99 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Only £14.99 inc VAT.
ORDER NOW
