**Today Only 30/03/2012** Crucial Ballistix Tactical Tracer 8GB 1600MHz Memory & Corsair Vengeance
22 Aug 2010
Today Only memory deals :) Some at the lowest price in the UK!!!!
Corsair Vengeance 8GB (1x8GB) DDR3 PC3-12800C10 1600MHz Single Channel Module (CMZ8GX3M1A1600C10) @ £35.99 inc VAT
The new 8GB Vengeance DDR3 memory operates at 1.5V for compatibility with the new 2nd generation Intel® Core™ processor family and is guaranteed to operate at 1600MHz. Providing 8GB of rigorously-screened DRAM on a single module allows gamers and performance enthusiasts to build systems with 32GB of high-performance memory.
"Vengeance DDR3 memory is the premier choice for reliable, overclockable DRAM for system builders on a budget," said Giovanni Sena, Director of Memory Products at Corsair. "Our kits based on 8GB modules give builders, system integrators, and gaming enthusiasts the power to break the 16GB barrier."
Features
- 8GB Module
- Each module is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 10-10-10-27 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Only £35.99 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £41.99 inc VAT
Crucial is all about the win—and our complete line of Crucial Ballistix performance memory is proof of that commitment. Whether you're a casual enthusiast or hardcore gamer, the expanded Ballistix line delivers a choice of performance memory that meets your need for speed.
Are you ready to shed some light on your computer?
Play with even more bling — customized by you. The Ballistix Smart Tracer features activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom.
These Smart Tracer modules are available in either Blue/Orange or Red/Green LED color combinations that you can manipulate in real time, switching up the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on-the-fly! Turn on the lights — and turn up your performance — with Ballistix Smart Tracer memory.
Add to it the downloadable MOD utility, and you get the real-time temperature monitoring — and more!
Features:-
- Black PCB
- Black high performance CAMO ALU heatspreaders
- Ultimate performance memory
- Activity LED's (RED / GREEN)
- Temperature Probe
- Crucial MOD software compatible
- Each two module set is tested at 1600MHz
- Tactical heat spreader for performance
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- Two matched 4GB modules
- Lifetime Warranty
- Bulldozer compatible
Only £41.99 inc VAT.
ORDER NOW
Flashy shiny RAM!!! All we need is the blue ones to be on sale one day ;)
There are blue ones right? I didn't dream that....
Dual channel almost doubles bandwidth and needs at least 2 sticks, so if you only want 8gb 2*4 is better than 1*8, if you want 16gb 2*8 is better than 4*4 because it puts less stress on the memory controller to have fewer sticks. Note though that a lot of boards don't support more than 16gb of ram, i'm unsure if this means they can run 2*8gb sticks or only 4*4gb.
Thanks for the reply,
Is 2x8 addressed in the same way as 2x4 i.e. quicker than a single stick? (I know 16GB isn’t needed but for this price I might well go for it)
Hi ssmacc
not sure if they are addressed the same but yes 2 in dual channel will be faster than just one, but the bigger 8gb sticks have slower timmings!! (just so you are aware)
not sure how slower timmings would relate in real world difference you could notice...
maybe someone could advise
Yeah I think the timings are a little slower but not sure if this makes any real world difference (as you say), buying a new motherboard (z77) and CPU (Ivy) when available so just thinking about ram for this, won’t be upgrading for a while so might go for 16GB now (currently have a Q9550).
Any thoughts on 16 GB of this RAM welcome
