We've got some stonking graphics card deals for you today, get them while they are available!
HIS HD 7790 1024MB GDDR5 PCI-Express Graphics Card @ £99.95 inc VAT
The card is equipped with the widely acclaimed HIS iCooler – certified by HIS that the card is quiet with noise level below 28dB when watching movies, surfing Facebook, working. . HIS iCooler provides an outstanding cooling performance and quiet environment. With HIS iCooler, the life span of the card is maximized while the noise level is minimized! You feel the quietness when viewing photos, browsing webs and checking your email.
Features:-
- Core Clock: 1000MHz
- Memory: 1024MB GDDR5
- Memory Clock: 6000MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 896
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x DVI, 1x HDMI & 1x DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Only £99.95 inc VAT.
ORDER NOW
Key Features
Unlocked Digital Power
- Unlocked BIOS: One click to unlock all protections for extreme overclocking
- Digital PWM Controller: More stable and precise voltage by digital signal
- Enhanced Power Design: 2X Power output for maximum OC potential
GPU Reactor
- An add-on device on the back of R7970 Lightning (Behind GPU) for the overclocking stability
- Provide 88% higher power capacity and eliminate power noise (ripple)
Xtreme Thermal
- Dust Removal technology on Twin Frozr IV keeps dust out for the best thermal condition
- Dual Form-in-one Heatsinks provide better heat dissipation and strengthen the structure
Military Class III Components
- Meet MIL-STD-810G standard to ensure the best stability and quality.
- Adopt CopperMOS, Hi-c CAP, Golden SSC, and Dark Solid CAP
Specifications
Graphics Engine ATI Radeon HD 7970
Interface PCI Express x16 3.0
Memory Type GDDR5
Memory Size(MB) 3072
Memory Interface 384 bits
Core Clock Speed(MHz) 1070
Boost Clock Speed(MHz) 1150
Memory Clock Speed(MHz) 6000
DVI Output 2
Mini DisplayPort 4
HDCP Support Y
HDMI Support Y
Display Output (Max Resolution) 2560x1600
RAMDACs 400
DirectX Version Support 11
OpenGL Version Support 4.2
CrossFire Support Y
Card Dimension(mm) 305x135.5x40mm
Warranty 3 Year
Only £399.95 inc VAT.
ORDER NOW
Features:-
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Key Features
GPU Reactor
Xtreme Thermal
Specifications
Memory Type GDDR5
DVI Output 2
Mini DisplayPort 4
HDCP Support Y
HDMI Support Y
RAMDACs 400
CrossFire Support Y
Warranty 3 Year
ORDER NOW
