- 20 Jul 2009
- The bleak North East arm pit of Britain
Today only we have 25 units of the XFX ATI Radeon HD 5770 Single Slot 1024MB GDDR5 PCI-Express Graphics Card with Stalker & AVP Games for just £75.59 inc VAT saving over £8! The XFX 5770 still has enough horsepower to motor through the latest games with ease giving you plenty of gaming power for the money you pay.
We also have 15 units of the Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black only £233.99 inc VAT. Thats a saving of £16 for a massive 28" of gaming space!
XFX ATI Radeon HD 5770 Single Slot 1024MB GDDR5 PCI-Express Graphics Card with Stalker & AVP Games @ £75.59 inc VAT
There’s an ideal graphics card for every gamer, and the XFX ATI Radeon™ HD 5770 single slot graphics card is for the gamer looking for “ility,” as in “utility,” “stability,” and “reliability,” not to mention some excellent overclocking “capability.” A single-slot card variant of the 5700 performance card family, it sports a uniquely designed fansink, with a total heatpipe surface area that is 15% greater than the HD 5770 dual slot channel fansink. This, combined with the open space provided by the single slot environment, ensures maximum airflow to the GPU.
An acoustic comparison of the 5700 family found that the XFX ATI Radeon HD 5770 single slot was up to 23.5 dB lower than the HD 5770 dual slot full cover fansink. Enhanced cooling and reduced noise is helped by fan speed, which is controlled by a PWM circuit on the PCB. Dust levels are kept down to a minimum with IP-5X dust protection standard. For gamers who have been waiting for the ideal single-slot graphics card, the XFX ATI Radeon HD 5770 has been worth the wait. The unique cooling capacity—and reduced noise levels—of this single-slot solution turns up the “ility,” making this a very attractive graphics card indeed.
- Single Slot Design!!
- Core Clock: 850MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I & 1 Mini DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
- Supplied with Stalker: Call of Pripyat & Aliens VS Predator Games (Subject to availability)
Was £83.99 Inc. VAT
Only £75.59 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £233.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 15000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
- Warranty: 3 Years On-Site
Was £249.99 Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
http://www.overclockers.co.uk/showproduct.php?prodid=MO-001-HS
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £83.99 Inc. VAT
ORDER NOW
- VESA Compliant
- Weight: 8.5kg
ORDER NOW
