**Today Only 30/09/2011** Roccat Kave 5.1 Surround Sound Headset (BEST PRICE IN UK) & Corsair Force
22 Aug 2010
Today only, game in full 5.1 and always hear the enemy with the Roccat Kave 5.1 Surround Sound headset and never miss a foodstep. Sound is as important as a good monitor, now you can get this epic headset at the best price in the UK!
Increase your computers performance with faster game loading times, instant media browsing with the Corsair Force Series 3 120GB SATA 6Gb/s. Perfect if you want to make your PC lightning fast!
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £124.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
- 2.5" - 3.5" Adaptor Included.
** FIRMWARE ISSUE FREE **
Only £124.99 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £59.98 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game setting
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Only £59.98 inc VAT.
ORDER NOW
Dont mean to be cheeky, but are there any impending offers on the Corsair 600TM?
I have just bought 2x 6970's off you guys and need a larger case to house them.
Just looking to save a little money, all I've been doing is spending this month!
It's only £5 off. Still, £5 is £5.
Quick question about the Kave - can you get sound using only the USB connection, even if it's only stereo? It's worth asking as I currently don't have a dedicated sound card but might get one later.
Nope, the USB is the amp which is required even for Stereo because the headset is very powerful and includes a desktop remote control unit. It's a fantastic price for the deal
