**TODAY ONLY! 31/03/2015** KFA2 GeForce GTX 970 OC "Silent" Infin8 Edt. & Asus GeForce GTX 980 Direc
OcUK Staff
4 Feb 2013
KFA2 GeForce GTX 970 OC Silent "Infin8 Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £269.99 inc VAT
Since Overclockers UK introduced our Infin8 system range, demand for high performance zero compromise systems has exploded. Our Infin8 brand represents performance hardware coupled with a unique and stylish aesthetic.
Since the release of high end Maxwell architecture, the hardware game has changed. The new GeForce cards offer revolutionary new technologies and class leading performance alongside low operating temperatures and impressive power consumption.
The GALAX GeForce GTX 970 OC Silent "Infin8 Black Edition" is a collaboration of one of the largest Nvidia board partners worldwide, Overclockers UK Graphics Specialist: Andrew Gibson and Overclockers UK Technical Specialist & Overclocking World Champion, Ian ‘8Pack’ Parry.
Originally the Galax 970 EX OC Black Edition was intended as a high performance option for customers looking for the ultimate gaming experience with class leading performance. Our close partnership with Galax allowed us to specify a list of important modifications that would make the GALAX GeForce GTX 970 OC Silent "Infin8 Black Edition" a real show stopper.
Primarily, to fit the Infinity aesthetic, we demanded that the external design of our Black Edition card was sleek and stealthy. Adding to the already imposing look of the Galax design, this new, aggressive appearance really highlights the intent behind this product.
Additionally to the colour change, we included a nickel plated I/O plate, heatsink and heatpipes to compliment the premium nature of the product. The already impressive backplate on the card has been accented with a stylish "Infinity: Inspired by 8 Pack" decal.
The imposing looks of the card would be nothing without the ‘go’ to back up all the show.
Building on the already impressive performance of the GTX 970 platform, world class overclocking expertise from 8Pack has been implemented to fine tune the BIOS of this card to achieve maximum safe, reliable performance from the GTX 970.
As an industry leading gaming and high end hardware specialist, Overclockers UK understands the importance of offering a product that meets a customer’s expectation. A major worry for any enthusiast is operational noise under load. We have used this knowledge to reduce coil whine by using higher quality components and also using glue to attach the inductors to the PCB to help reduce electrical vibrations which help reduce whine.
This collaboration with Galax has allowed us to build what we believe to be the finest example of a GTX 970 on the market today.
This product is exclusively available from Overclockers UK and Caseking group throughout UK and Europe. We suggest European customers visit www.caseking.de to purchase this card in Western Europe and Eastern European customers purchase from http://www.kellytech.hu/
Features:-
- OcUK Zero Coil Whine guarantee*
- Samsung memory guarantee
- All Black Design!
- Nickel plated I/O Plate
- Nickel plated heatsink and heatpipe
- All black shroud/cooling design
- Black PCB
- Black Backplate with Inspired by 8 Pack logo
- Inductors placed in higher quality containers and glued to PCB to reduce coil whine
- Extreme factory overclock with huge OC potential
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Dimensions: 260mm (L) x 120mm (H) x 40mm (W)
- Zero coil whine guarantee
- KitGuru Review: http://www.kitguru.net/components/g...rce-gtx-970-oc-silent-infinity-black-edition/
- Warranty: 2yr
*If your card emits any coilwhine when used on a decent power supply that is 80+ Gold rated or higher then OcUK will refund or exchange the card. These cards incorporate our exclusive Coil Whine Reduction technology to help reduce and eliminate any whine.
Only £269.99 inc VAT.
ORDER NOW
______
Asus GeForce GTX 980 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £449.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Boost Clock: 1279MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £449.99 inc VAT.
ORDER NOW
Ah go on then it's about time I replaced my trusty 4 year old MSI GTX470, & I think one of those KFA2 GTX 970 OC will do the job nicely.
The 970 deal, so tempting considering the free delivery on the entire basket! I'm tempted to pick up 2 and upgrade from my single 670, though I'm scared of the whole "ramgate" issue thing with the 3.5GB+ buffer zone :(
